 Clean pair valve..mod
3rdcoastcb1100_imp Offline
Threads: 2
I’ve seen a couple of pair valve mod jobs and figured I’d offer up another option for those who are interested. I will add that this is pretty simple and straight forward. This kit will run you $45 usd.
The kit has billet block offs plus the necessary hardware
1 cap to plug off the inlet into the air box
1 plug for the harness so you don’t toss a CEL
1. Pull the seat
2. Pull both side covers
3. Pull tank by removing the vent tube and disconnecting the fuel line (Don’t forget step 2 because the black connector is the fuel pump)
4. Under the neck, locate the air pump and unplug it
5. Use the supplied bypass plug and tuck everything under the harness
6. Remove the pump assy.
7. Pull all the related hoses. The longest hose runs to the airbox where you will use the supplied cap to plug it off. It helps to have the covers off.
8. Remove the oem pair covers.
9. I opted to gut the reeds but use the rubber bodies to help with sealing.
10. Reinstall tank and plug fuel pump back in. Be sure to prime the system to make sure you have no leaks.
11. Install side covers and seat. Done
05-21-2020, 02:46 PM
ozigoo Offline
South Australia
Threads: 23
RE: Clean pair valve..mod
Sorry for my ignorance, but what does this do?
05-21-2020, 06:19 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Ozi, the PAIR valve system is part of the emission control system.
From the Manual: The exhaust emission control system is composed of a pulse secondary air supply system, a 3-way ctalytic converter and PGM-FI system.
The pulse secondary air supply system introduces filtered air into the exhaust gases in the exhaust port. Fresh air is drawn into the exhaust port by the function of the PAIR control valve.
This charge of fresh air promotes burning of the unburned exhaust gases and changes a considerable amount of hydrocarbons and carbon monixide into relatively harmless carbon dioxide and water vapor.
The freed valve prevent reverse air flow through the system The PAIR control valve is operated by the solenoid valve. The solenoid valve is controlled by the PGM-FI unit and the fresh air passage is opened/closed according to the running condition.
OK, after all that, the PAIR valve mod will eliminate most/all popping that occurs on deceleration when using an aftermarket exhaust system.
05-21-2020, 08:33 PM
ozigoo Offline
South Australia
Threads: 23
Any HP gains?
05-21-2020, 09:53 PM
Lord Popgun Offline
Virginia
Likes Given: 142
Not my area of expertise but I don’t think so. After market exhaust? I guess. Powerdubs or Pekingduck or someone can address that. Main purpose of the PAIR mod is to stop the popping on decel.
3rdcoast, how about a link to the kit.
05-21-2020, 09:59 PM
Threads: 2
(05-21-2020, 09:59 PM)Lord Popgun_imp Wrote: Not my area of expertise but I don’t think so. After market exhaust? I guess. Powerdubs or Pekingduck or someone can address that. Main purpose of the PAIR mod is to stop the popping on decel.
Sorry about that. Here you go
https://smartmoto-electronics.com/comple...ple-126-en
(05-21-2020, 09:53 PM)ozigoo_imp Wrote: Any HP gains?
No hp gains. I did it for simplicity. I think it just looks better without all the hoses and mess coming out of the top of the motor. I do know it’ll reduce the popping from the exhaust but I don’t mind those little noises. Aesthetics and cleanliness is my thing
05-21-2020, 10:50 PM
teamvisegrip_imp Offline
Threads: 4
I bought the Plates From Webike and installed them on mine. Very simple to install... Remove the Covers and put on top of the Valve Plate. Everything stays in place. Job done. I do not remember blocking off anything.
With the TSR Intake Funnels and Air Filter Cover with the Yoshimura pipe I had to do it. Now it runs like a champ! No annoying popping or anything.
05-22-2020, 01:09 AM
Threads: 2
(05-22-2020, 01:09 AM)teamvisegrip_imp Wrote: I bought the Plates From Webike and installed them on mine. Very simple to install... Remove the Covers and put on top of the Valve Plate. Everything stays in place. Job done. I do not remember blocking off anything.
If your sitting on the bike at the top right corner of the airbox there is a long hose that gets removed and capped off.
05-22-2020, 01:39 AM
LongRanger_imp Offline
Threads: 129
3rdcoast, I'll buy your leftover LHS pair cover #12333-MGC-N00 (just the cover, no bolts, hoses, or underlying components) if you don't intend to keep it. Mine's discolored for some reason. New ones go for $32, so I'd be in for half price ($16) if you're interested. If so, PM me.
05-22-2020, 01:51 AM
furious_blue_imp Offline
Threads: 11
It's funny, nowadays it seems like popping on throttle let off is all the rage with the car enthusiasts. The more of it and the louder, the better !
05-22-2020, 02:27 AM
  Stripped the valve cover PowerDubs_imp 25 1,589 11-18-2021, 10:19 PM
  valve stem replacement without removing tyre max 5 554 01-08-2021, 10:46 AM
  Inlet and exhaust valve sizes Bradders_imp 12 939 10-17-2018, 08:33 AM
  A Clean Little 69 Cent Mod. 2017EX_imp 5 435 06-06-2018, 02:40 AM
Last Post: 2017EX_imp
  Pair valve delete...i need photos -_- JohnHighlander_imp 2 287 05-30-2018, 05:21 AM
Last Post: Ferrealls_imp
  Tyre Valve Cap Replacements MrTim_imp 5 482 07-15-2017, 08:31 AM
  83 degree valve stems the Ferret 10 780 04-07-2016, 09:57 AM
Last Post: Pterodactyl_imp
  Watch "cb1100 remus exhaust pair valve blocked" on YouTube fredkb_imp 14 1,039 11-23-2014, 01:43 AM
Last Post: fredkb_imp
  Ram ball mount! Quick & clean Ridem32_imp 6 431 06-25-2014, 02:36 AM
Last Post: Ridem32_imp
  Arrow Slip On and PAIR Valve Mod Jettster_imp 5 423 06-09-2014, 09:00 AM
Last Post: kevbroce_imp
