Bar end weight replacement
Gone in 60 Offline
Blood Biker of the Apocalypse
Orange County, CA
Threads: 245
Likes Received: 1,196 in 513 posts
Likes Given: 968
Hi guys, something is puzzling me. The only visual blemish that's bugging me on the '13 I just bought is a mark on one of the bar end weights where the P.O. bumped the bar on the edge of his garage.
I pulled off both of the factory end weights and repainted them. I didn't pay a heck of a lot of attention when I removed them, but putting them back on, they do not appear to go inside the handle bar, but rather they butt up against the bar. This gives a sizable gap between the weight and the grip (maybe 3/16") I didn't notice that gap before I pulled them off, but wasn't paying close attention.
Is a gap between the end weights and grips normal? Anyone available to check their '13 (or '14 as well if the bars are the same) and let me know if there should be a gap? The outside diameter of the weight is slightly larger than the inside diameter of the bar, clearly it's not designed to go inside unless I'm doing something wrong...
04-12-2019, 02:12 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Bar end weight replacement
IIRC the end of the weight has a half moon shape that engages with the damper in the bar. Make sure it is oriented correctly.
As for the gap, I'll check mine after work.
I would suggest you use some blue Loc-tite on the screw. There have been reports of the weight departing the bike unexpectedly. The manual may say that too, I'll have to check.
04-12-2019, 02:17 AM
(04-12-2019, 02:17 AM)Lord Popgun_imp Wrote: IIRC the end of the weight has a half moon shape that engages with the damper in the bar. Make sure it is oriented correctly.
PG: To clarify, you are saying the end weights are keyed?
04-12-2019, 02:19 AM
Lord Popgun Offline
Virginia
Likes Given: 142
GO, yeah, sorta. Not a tight fit or anything. I'll look at mine when I get home. I have a set for the ST that is the same on the end. Or just pull one off my CB. Just a screw Smile IIRC the half moon is just to keep it from rotating.
04-12-2019, 02:26 AM
(04-12-2019, 02:26 AM)Lord Popgun_imp Wrote: GO, yeah, sorta. Not a tight fit or anything. I'll look at mine when I get home. I have a set for the ST that is the same on the end. Or just pull one off my CB. Just a screw Smile IIRC the half moon is just to keep it from rotating.
Yes, that makes sense!
04-12-2019, 02:28 AM
Gone in 60 Offline
Orange County, CA
Threads: 245
Likes Given: 968
Yup, I noted the half-moon, sorta yin-yang way they go together, just seems weird that the front part of the weight necks down but not enough to fit inside the bar. I know the part that expands and locks it in place is inside the bar.
04-12-2019, 03:36 AM
Lord Popgun Offline
Virginia
Likes Given: 142
I measured mine and they are spaced away 3/16”. I’d say thats normal.
04-12-2019, 06:35 AM
Gone in 60 Offline
Orange County, CA
Threads: 245
Likes Given: 968
Well thank you! Good to know I didn’t booger something up.
I can live with that.
04-12-2019, 07:30 AM
Likes Given: 1,010
http://cb1100forum.com/forum/showthread.php?tid=11229
04-12-2019, 08:01 AM
Houtman_imp Offline
Threads: 115
I put an right sized O ring in the gaps to make it look better and still be able to turn the throttle freely , same on the clutch side .
04-12-2019, 08:32 AM
  LED Headlamp Replacement Davidjill_imp 14 1,423 12-31-2024, 02:21 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 665 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  HP Torque, Weight etc pdedse 9 948 03-05-2024, 10:04 PM
  Hepco Becker Replacement Key tomcat_imp 5 595 08-10-2023, 03:20 AM
  Wrecked my CB, need OEM or Aftermarket replacement suggestions danieljrmurray_imp 12 900 09-15-2021, 05:51 AM
Last Post: teamvisegrip_imp
  Bar Weight Gap Fix? 2017EX_imp 16 1,158 01-30-2021, 04:53 PM
Last Post: Jfro5687_imp
  valve stem replacement without removing tyre max 5 539 01-08-2021, 10:46 AM
  Vario Footpeg replacement mounting bolts Ojiisan_imp 2 348 04-19-2018, 03:07 AM
Last Post: Ojiisan_imp
  Replacement Passenger Footpegs hb9400_imp 3 358 10-05-2017, 10:16 PM
Last Post: hb9400_imp
  Beautiful replacement tank for the 2014 STD CB4ME_imp 23 2,741 01-11-2017, 03:30 AM
Last Post: Nortoon_imp
