O2 Sensor Socket
Instead of paying $35 to $50 for a special flare socket, I have made my own in about 15 minutes.
Using a 17 mm 3/8 drive deep socket bought for $5 at Northern Tools and using painters tape to mark the area to be ground off, which I did with a 4.5 inch angle grinder.
Keep water on hand to cool the socket in between grinding to prevent bluing and losing its temper!!
It works perfectly. A damn sight easier then trying to add the picture for all of you to see my handiwork.
[url=http://s1360.photobucket.com/user/JohnMBHoutman/media/009_zpse41aafac.jpg.html][Image: 312d26241fac7d0381a8add903056f73.jpg]
[url=http://s1360.photobucket.com/user/JohnMBHoutman/media/009_zpse41aafac.jpg.html][Image: b20be6b71fb533ca470f6ce555a1dcbf.jpg]
Great idea. Thanks for sharing!
I assume you need this tool only if you are changing exhaust systems?
Similar but different:
I've made a couple "banjo" wrenches over the years. That's a box-end wrench with s slot cut out so you can slide it over brake and fuel lines onto the coupling nut. They help avoid rounding the nut vs. a regular open-end that only grips two sides.
Super easy to make, worth the effort to avoid damaging those nuts.
Houtman, Good job. How long did it take for you to make?
I sucked it in and bought the Koken socket....
I went cheap and used an old wrench.
(12-14-2013, 01:41 AM)The Spaceman_imp Wrote: Similar but different:
That's where the older 6-sided wrenches are better than the
newer 12-sided which kinda can slip around slightly and
cause an old rusty nut to strip out { get round }.
Props to cbfan for getting it out with that wrench. Mine was crazy tight and there is almost no clearance. I ate the $35 for the Koken.
Holy crap, that does look like a tight fit.
yep, tight but alittle liquid wrench and firmly holding down on the wrench got it out with no major dramas.
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,682 03-06-2026, 04:31 AM
  Oxygen lambda o2 sensor eliminator kit Davidjill_imp 4 565 11-09-2025, 06:23 AM
Last Post: AndyBeeMD
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 845 10-22-2025, 02:11 PM
  How to remove O2 sensor CB1100AZ_imp 10 874 12-13-2024, 09:57 AM
Last Post: inditx_imp
  Spark plug socket. Jgarciajr40_imp 5 551 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  Bank angle sensor. Tezza_imp 8 752 08-06-2023, 05:57 PM
Last Post: Jurlie_imp
  fuel level sensor MBZM Rai_imp 11 904 04-11-2023, 11:38 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,362 06-03-2022, 01:16 PM
  HONDA Oxygen Sensor Eliminator CB 1100 2013-2016 Enzofour_imp 1 273 03-07-2021, 05:16 PM
Last Post: jtopiso_imp
  speed sensor output Lord Popgun 16 1,093 10-09-2020, 09:20 AM
