Threads: 1
I have broken the sensor when falling.
I ask for help you,
report the electric circuit of the sensor or
report data on resistance at various fuel level (Ohm)
Thank you in advance
CB 1100 SA EX 2015
Likes Given: 1,002
Welcome Rai. Where are you from? Which model CB1100 do you have?
I'm sure someone will be able to help you.
Likes Given: 140
That little circuit card is broken in two. You are going to have to buy a new fuel pump assm. as the sender parts are not sold separately.
Threads: 1
Popgun , it very easy. People can make, if to give the scheme of the workink chip.
Likes Given: 140
I'll check the service manual tonight, but I don't think that info is in there. And I'm not taking mine apart to measure it
Finding someone to make one in the US would end up costing more than a new pump. You are lucky if you have that capability.
Likes Received: 587 in 321 posts
Likes Given: 991
(07-24-2017, 01:44 PM)Rai_imp Wrote: I have broken the sensor when falling.
I ask for help you,
CB 1100 SA EX 2015
Hi Rai,
My service manual 2013-14 does NOT indicate ANY specs/ resistance for gas sending unit ...but if you still have your old one and if it is cracked/broken just below 2 soldering points (as per your pic), with a little skills and luck, you will be able to get its original specs by measuring resistance (Ohms) at Empty and Full position*. All you need is an Ohmeter. Your gas sending unit is nothing else but a variable resistor and its resistance can continuously be measured between 2 terminals while moving float from Empty to Full or vice versa*. You can record as many readings as possible*. Simple. DO IT.
*I made my diagnose based on 2013-14 diagram, NOT 2015 and I believe is the same as far as diagnosis are concerned.
Good luck!!
Peter
Likes Given: 140
Peter, thanks for looking. Now I don't have to
I had the same thoughts as you, but the black thing by the top connection may be a resistor. And its split in half. So, I didn't offer any troubleshooting tips, not knowing for sure.
Ok, after typing that, in the manual, for After '13 model (that means the 2014 models) on page 19-28 it says that for resistance:
Full: 5-7 ohms
Empty: 204-210 ohms
Thats it for resistance readings. Hope this helps.
To add, for those wondering, for 2013 the readings are full, 8-12 ohms and empty 213-219 ohms.
Threads: 1
I will test. If to appear information, write here. I am very glad that you have responded and you help.
thanks a lot =)
Likes Given: 991
(07-26-2017, 03:36 PM)Rai_imp Wrote: I will test. If to appear information, write here. I am very glad that you have responded and you help.
thanks a lot =)
Hi Rai,
A month ago, we provided you with all the information you needed... specs, how to test it, ++++ and since then there is no update from your side...could you be so kind and let us know how you fix your problem with your fuel sending sensor, etc...
Cheers,
Peter
Threads: 1
We made it.
Also the tachometer did not work, for it the amplifier was soldered
Just in case I throw off contacts of the master (Can to whom it is useful)
https://vk.com/fokin_alexey
Many thanks to all =)
