How to remove O2 sensor
I have a 2013 CB1100 that I am planning to remove the header and have it Jet Hot or ceramic coated. I have a 17mm deep socket that I am going to cut a slot in in order to accomodate the sensor wire when I remove the O2 sensor from the header. Should I disconnect the sensor from the wiring harness and remove it along with the header or is there enough slack in the wire to allow me to drop the header down far enough to remove the sensor from the header while the sensor is still on the bike? Also can I expect the sensor to unsrew relatively easy from the header or will it be difficult to remove because of the heating and cooling of the header?
Any tips on the removal process will be appreciated.
OEM socket or:
http://cb1100forum.com/forum/showthread....light=tool
(05-29-2020, 01:39 AM)peterbaron_imp Wrote: OEM socket or:
Thanks
Like I said I know how to make the modification to the socket in order to make the tool to remove the sensor. I am wondering whether I need to remove the sensor with the header and then remove it from the header or can I remove the sensor from the header before I remove the header from the bike.
You can do it either way , what ever you think you might find easier , the sensor is quite tight but not difficult to remove with and 3/8 drive deep socket cut along its length to the bottom , cutting of about a 1/4 of the diameter of the socket is enough .
(05-29-2020, 06:24 AM)Houtman_imp Wrote: You can do it either way , what ever you think you might find easier , the sensor is quite tight but not difficult to remove with and 3/8 drive deep socket cut along its length to the bottom , cutting of about a 1/4 of the diameter of the socket is enough .
Can you explain what you mean by "cutting of about a 1/4 of the diameter of the socket is enough "?
If you think of the socket being 360 degree round with 6 flats than you can cut one flat away along the LENGHT of the deep socket till you come to the bottom of the socket. An angle grinder works best.
I thought there a kind of wrench/socket for these call line/flare wrench?? Its available in those bigger hardware stores. Six sided but with an opening for wires/tube/hose to pass thru. Mostly people use it for high pressure hydraulic line.
Just hop on Amazon and type in O2 sensor tool and there are a bunch of different styles, sizes, reach, leverage...
What size is the sensor nut please?
inditx
M17
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,672 03-06-2026, 04:31 AM
  Oxygen lambda o2 sensor eliminator kit Davidjill_imp 4 563 11-09-2025, 06:23 AM
Last Post: AndyBeeMD
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 843 10-22-2025, 02:11 PM
  Bank angle sensor. Tezza_imp 8 750 08-06-2023, 05:57 PM
Last Post: Jurlie_imp
  fuel level sensor MBZM Rai_imp 11 899 04-11-2023, 11:38 PM
  Help - Overfilled Oil, how to remove? saru2011_imp 25 1,796 08-18-2022, 08:31 AM
Last Post: ymtnpoah11_imp
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,339 06-03-2022, 01:16 PM
  How to remove both wheels? RandyBMC_imp 18 1,392 05-10-2022, 11:12 PM
Last Post: Tom_imp
  HONDA Oxygen Sensor Eliminator CB 1100 2013-2016 Enzofour_imp 1 271 03-07-2021, 05:16 PM
Last Post: jtopiso_imp
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,281 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
