Torque Settings
Hi
I would like to know the Torque settings for the Engine Mounting M10 bolts that are at the front of the Engine under the Oil Cooler. Long story involving engine sliders/brackets that didn`t quite fit properly so the original bolts have gone back in until I either make new spacers or the slider manufacturer supplies them.
Also looking to buy or download a workshop manual for my CB1100 if anyone can point me in the right direction.
Have a safe and happy New Year,
Hi Tyke57NZ
Torques for the 4X "through frame" bolts / nuts is 49Nm.
I got my manual from here http://www.sell.com/2G7335
(12-25-2013, 08:19 PM)Kiwikevin_imp Wrote: Hi Tyke57NZ
Hi Kiwikevin
Thanks for that info, I assumed the 2 x through bolts for the Engine to mounting plate would be the same, would you mind looking those up for me. I will have to set up a Pay Pal account to purchase that manual but I will get onto that later.
Where in NZ are you?
Workshop manuals and sourcing them was discussed here, http://cb1100forum.com/forum/archive/ind...18-1.html.
Kiwikevin, is the one from sell.com ok?
(12-26-2013, 06:33 AM)Cormanus_imp Wrote: Workshop manuals and sourcing them was discussed here, http://cb1100forum.com/forum/archive/ind...18-1.html.
Went to the Helm site and its US$127 to post to NZ, total cost US$222 so might be going with the sell.com item, from the thread I believe its an OK item but perhaps Kiwikevin would confirm.
Hi Guys, yes good quality print, bound with clear plastic cover!
I'm Happy!
I'm Happy!
I'm Happy!
Cheers for that, off for a ride now before the weather turns grotty.
The sell.com one may be "OK" but it's a totally illegal copy some guy is printing in his basement.
Hi Kiwikevin
Hi Kiwikevin
Yes torques are the same for the 4 bolts that go through the frame. The other 2 (1 each side) that go through the front engine bracket/s are 59Nm.
Hope this helps.
Hi Kiwikevin
Hi Kiwikevin
Hope this helps.
Hi Kiwikevin
Hope this helps. Excellent, thanks for the info. I will get the manual from sell.com as it is $200+ cheaper landed at my door; US$157 just for shipping and handling seems a little over the top for a manual.
  Torque value question Jonnyteabag_imp 9 666 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 652 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 428 04-03-2021, 01:35 AM
  Engine mount bolt torque value TCinNC_imp 43 2,711 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Shock bolt torque HBFL_imp 9 728 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,137 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,236 10-25-2018, 02:25 AM
Last Post: HBFL_imp
  Torque spec for motor mount? PAULIBIKER_imp 3 399 09-10-2018, 07:35 AM
  Torque wrench woes postoak_imp 17 1,067 08-10-2018, 08:44 PM
  Oil filter torque values Houtman_imp 23 1,501 04-05-2018, 08:49 AM
