Torque wrench woes
Twice now, I have snapped bolts when my torque wrench didn't "click" at the set weight. This is with two different torque wrenches. (I suppose I could have made a mistake in the setting, but I don't think so.) Anybody every have this happen to them?
I no longer trust that type of torque wrench! I am going to go back to the old style with the needle. At least with it you can see where you are in a continuum on the torque scale.
What's annoying is in both these cases I could have just gone by feel and been just fine.
No, I haven't but fear it could happen, although I mostly use it for torquing the rear axle nut and doubt I'd ever snap that baby off.
Yeah, after I posted I did a google search on something like this happening and found some hits. I would never trust this type torque wrench again.
Always store that style of wrench with the tension off the spring (loosen all the way).
The smaller the wrench, the less 'click' they tend to make. You must keep an eye on them and watch and feel for the movement.
I'm not a fan of the old school needle bar- too much leeway.
If I used a tq wrench more often on critical stuff (engine internals) I would go in the other direction and get a good digital one.
I have a nice one but generally just go by feel. experience on what diameter the bolt , type of metal and amount of stress the part may take has allowed me to never over tighten or anything come loose. have used Lock tight on my Harley's but that problem has been solved ..........
I use my elbow as a torque wrench. Never snapped a bolt, and never had a leak.
(08-10-2018, 04:49 AM)postoak_imp Wrote: Twice now, I have snapped bolts when my torque wrench didn't "click" at the set weight. This is with two different torque wrenches. (I suppose I could have made a mistake in the setting, but I don't think so.) Anybody every have this happen to them?
Q1.
How did you approach torquing...did you try to torque nut/bolt that was already tight/torqued or first you cracked it loose...was your bolt/nut lubed or dry and of what size and length??...it matters
Q2 What was your TW set at?
Hope you are not talking about angle torque and your wrench was set OK and in good working condition (always store TW in rest position)
The old style with needle, explains for itself Undecided
Smile
(08-10-2018, 07:59 AM)DBM_imp Wrote: I use my elbow as a torque wrench. Never snapped a bolt, and never had a leak.
Hope you’ve never worked on engine internals, bearing clearances, etc.
Tq specs aren’t just for keeping bolts from falling out or snapping.
Yeah, I know to keep the wrench stored at zero, but admit I forgot this time -- maybe that did it. As for the smaller one, at the time I thought to myself that I had already tightened the nut past the the small value required, and maybe I did, but I doubt it.
The older needle type may not be as accurate, but at least you won't go way past the value called for waiting for a click.
As for the oil, I am usually just putting back on a bolt or nut I have previously removed with no additional oil added.
DBM I use my elbow as a torque wrench. Never snapped a bolt, and never had a leak = ROFL...don't get upset...we ekil your elbow torque..lol...
and see below why:
PD Hope you’ve never worked on engine internals, bearing clearances,... = +1 Thumbs Up
Beer
  Torque value question Jonnyteabag_imp 9 666 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 652 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 428 04-03-2021, 01:35 AM
  Alloy Sprocket woes Ninemeister_imp 22 1,753 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Engine mount bolt torque value TCinNC_imp 43 2,711 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Shock bolt torque HBFL_imp 9 728 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,137 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,236 10-25-2018, 02:25 AM
Last Post: HBFL_imp
  Torque spec for motor mount? PAULIBIKER_imp 3 399 09-10-2018, 07:35 AM
  3 in 1 Filter Wrench, 17mm Magnetic Drain Bolt, OEM Oil Filter, Crush Washers? LordWasr_imp 25 1,599 04-23-2018, 08:54 AM
Last Post: LordWasr_imp
