Torque value question
Hi all, can anyone tell me the torque value for the front engine mounts-specifically the bolts at the front engine lugs?
It seems that a workshop manual is not available in the UK for the 17 EX/RS models..well not in paper format anyway, what Honda want you to do is buy a pass to see the relevent parts of the shop manual and I believe it's on a time limit too!
Cheers,
JT
44 lbf or 59 nm
frame side are 49nm 36lbf
says to torque the nut side not the bolt head side
Many thanks sir!
JT
yes sir send me a private meassage
Did you mean to post in this thread 1973cb750, or does this relate to your discussion with PowerDubs?
yes i did i have a link to a manual id share with him ?
Couldn't see a link on a quick scan, but, if [url=http://cb1100forum.com/forum/showthread.php?tid=17343&pid=332680#pid332680]this was the thread I'll move your earlier post to it for you.
Ok your confusing me totally I ment to reply to this thread he asked for torque specs I gave them then told him to private message me so I could give him a manual what is the issue ?
No issue. I misunderstood. Apologies.
its all good i thought he needed a manual so i sent a copy over
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 642 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 394 04-03-2021, 01:35 AM
  Engine mount bolt torque value TCinNC_imp 43 2,537 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Shock bolt torque HBFL_imp 9 679 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,091 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,192 10-25-2018, 02:25 AM
Last Post: HBFL_imp
  Torque spec for motor mount? PAULIBIKER_imp 3 378 09-10-2018, 07:35 AM
  Torque wrench woes postoak_imp 17 1,022 08-10-2018, 08:44 PM
  Oil filter torque values Houtman_imp 23 1,454 04-05-2018, 08:49 AM
  Torque Specs for fuel pump Mscb1100_imp 5 492 03-13-2018, 03:38 AM
Last Post: Flytech99_imp
