Shock bolt torque
No luck searching, anyone with the rear shock bolt torque specs? Thanks !
I can check when I get home, but the top one is like 6 inch pounds. Yes, inch pounds. It will wring off very easily. A couple of members found that out the hard way.
OK, found my shock bolt torque post. Ignore the above, I was wrong.
Here it is:
6.6 ft/lbs upper mounting bolt
Lower is 19 ft/lbs
(04-10-2019, 03:45 AM)Lord Popgun_imp Wrote: I can check when I get home, but the top one is like 6 inch pounds. Yes, inch pounds. It will wring off very easily. A couple of members found that out the hard way.
Here it is:
Lower is 19 ft/lbs
Thanks!!
Here it is:
Lower is 19 ft/lbs
[ft·lbs] and not [ft/lbs], to be precise (or a bit fussy)
Dodgy
OK, well how do you make a dot like that? My iPad and iPhone will make a dot like that but it is big and bold. And, I don't know how to do it on a PC keyboard either Blush
It is a product of two metrics, so asterisk "*" could do, but looks funky, or many use the hyphen "-", but not interpreted as a negative. The dot is cute and can be interpreted as a product operation.
(04-10-2019, 09:42 PM)Lord Popgun_imp Wrote: Dodgy
Well... on a Spanish PC keyboard it is [shift]+[3], although it's not a symbol used in Spanish language (it is used in Catalan, I reckon), but it's handy writing math expresions or units.
(and now I've learnt it has a name! https://en.wikipedia.org/wiki/Interpunct )
https://middot.net/ Shows how to produce the interpunct or middot on a computer keyboard. Can’t find how to do it on iOS.
ft-lbs is acceptable.
Too many characters. Use Nm (Newton meter) and you can leave the dot away. Tongue
Funny how when something new appears once it suddenly recurs. Here’s an example of using • as an interpunct.
[url=https://postimg.cc/zLMngL02][Image: aa759fa9e8133a1a22a63f96a8869f56.jpg]
  Another shock thread, but SHOWA JLEECB 17 1,590 02-09-2025, 11:23 PM
  Front sprocket bolt cant be moved misterprofessionality 55 4,434 03-13-2023, 12:18 PM
  Torque value question Jonnyteabag_imp 9 636 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 639 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Rear shock adjustment for pillion and bags alexzanutto_imp 6 600 07-20-2021, 07:49 AM
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 391 04-03-2021, 01:35 AM
  Fork Tube hex head bolt tool fitment ? bflint 8 671 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Engine mount bolt torque value TCinNC_imp 43 2,531 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  torque specs? Flynbulldog_imp 30 2,088 03-09-2019, 01:13 AM
  Shock spring paint HBFL_imp 6 464 10-30-2018, 05:21 AM
Last Post: HBFL_imp
