Torque specs
I need oil bolt torque for front caliper/master cylinder
Oh and fork preload adjuster too.
Many thanks!!
If you mean the Brake Caliper Bleed valve, it is 4 ft lbs. Same for front and back.
I think you want the fork bolt (manual reference). The torque is 16 ft lbs. And the manual says to use a new o-ring if the assembly is removed and to oil it with fork oil. YMMV.
Popgun, you were faster this timeSad
Smile
(10-20-2018, 01:36 AM)peterbaron_imp Wrote: Popgun, you were faster this timeSad
Smile
Big Grin
I was surprised you had not answered it before I did. Beer
Smile
Big Grin
Big Grin
Yeah, well it took him 47 minutes to answer!
Big GrinThumbs UpBeer
Thanks all. I was putting on some braided brake lines, they called the bolt on the end of each line connecting to calipers and MC as "Oil line" I found the torque spec on the website.
I torqued the fork caps by "feel". Now I have nice bling gold caps to distract me. (not on my teeth)
Sorry about that HBFL. Peter or I would have been happy to list the torque but wasn’t sure what you wanted and thought you were maybe bleeding the brakes.
Just ask, we’ll get it to ya! Smile
(10-23-2018, 08:24 AM)Lord Popgun_imp Wrote: Sorry about that HBFL. Peter or I would have been happy to list the torque but wasn’t sure what you wanted and thought you were maybe bleeding the brakes.
Popgun, slow down and thanks for the recommendations Smile
No sweat folks!
  Torque value question Jonnyteabag_imp 9 675 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 655 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 432 04-03-2021, 01:35 AM
  Engine mount bolt torque value TCinNC_imp 43 2,794 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Spoked wheel run out specs Jfro5687_imp 3 326 04-19-2020, 06:35 AM
Last Post: Jfro5687_imp
  2014 cb1100 frame fork stem specs ck1100-smithbros_imp 13 922 04-13-2020, 05:47 AM
  Torque specs for handle bar clamp to triple clamp itstuantran_imp 8 671 07-11-2019, 10:16 PM
Last Post: itstuantran_imp
  Shock bolt torque HBFL_imp 9 744 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,146 03-09-2019, 01:13 AM
  Torque spec for motor mount? PAULIBIKER_imp 3 402 09-10-2018, 07:35 AM
