Engine mount bolt torque value
I received my SW MOTECH engine guards today. Would someone with a shop manual please tell me what the torque value of the engine mounting bolts is supposed to be? Thanks in advance.
In the '13 service manual:
For the 2 bolts that go through the frame downtube, nut torque is 36 ft. Lbs
For the bolt right by them that goes through the engine (then that long spacer to the triangle piece, nut torque is 44 ft. Lbs.
(04-06-2016, 10:21 AM)Lord Popgun_imp Wrote: In the '13 service manual:
Thanks Popgun, I appreciate it!!
TC, check your PM
I have a 2013/14 manual and the torque is the same - 44 ft. lbs.
I recently installed same bars. Bolts took some power to break loose. I may have tightened them more than 44 but put some loctite on them. I don't think they'll come loose.
Be careful to not grossly over torque, particularly in aluminium structures. Failure of the fastener or, more likely, the structure, may occur, particularly when loads and vibration as in engine mounts are concerned. That is why torque values are set, rather than "as tight as you can get".
I had the same experience during my installation. The bolts seemed to be significantly tighter than 44 ft. Lbs. They did get torqued to 44 according to my torque wrench when put back together.
I didn't go crazy cranking them down, but probably exceeded the spec torque. I just used a regular ratchet and went till nice and tight.
3 finger torque .....lol ol Skool
  Pictures of OEM Rear turn signal mount Houndwheels_imp 8 764 09-12-2023, 10:28 AM
Last Post: Houndwheels_imp
  Front sprocket bolt cant be moved misterprofessionality 55 4,461 03-13-2023, 12:18 PM
  Torque value question Jonnyteabag_imp 9 656 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 644 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 405 04-03-2021, 01:35 AM
  Fork Tube hex head bolt tool fitment ? bflint 8 696 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Location of Engine Number on Engine? cb1100_dude_imp 2 331 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  Shock bolt torque HBFL_imp 9 695 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,114 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,201 10-25-2018, 02:25 AM
Last Post: HBFL_imp
