Bar End & Internal Weight Removal
I stumbled across this procedure, had not seen it before, and thought I would pass it on. Most procedures I have seen for bar end and internal weight removal talk about left grip removal to access the retaining clip release holes in order to remove the internal weight. The right ( throttle ) side only requires taking off the switch housing to slide the grip/throttle tube off, and access the clip release holes. This guy has figured out that it is possible to roll the left side grip rubber back on itself, just enough to get at the clip release holes, without removing the grip. I think if I was going to try it, I would soften and expand the rubber first by heating it with a hair dryer. I dont think it would work with old hard rubber grips. Link attached to the showing the procedure. http://www.manicsalamander.com/media/519...emoval.pdf
I am lazy and just left them inside and installed new closed end grips
  Valve Adjustment and Camshaft Removal dave 5 631 03-21-2026, 04:49 PM
  Left side cover removal jeffmazz_imp 24 2,166 07-09-2025, 03:37 PM
Last Post: bflint
  Weight limit on genuine Honda rear rack DaveP_imp 14 1,245 11-17-2022, 02:57 AM
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 6,083 07-25-2022, 06:54 AM
  Easy bar end weight removal brian10x_imp 6 624 06-06-2022, 01:04 AM
Last Post: 1973cb750
   CB's max weight j3gq_imp 36 2,616 11-26-2020, 11:32 AM
  Air box removal ACE_IRA_imp 23 1,671 09-25-2020, 05:56 AM
Last Post: ACE_IRA_imp
  Wheel weight Brad14_imp 7 587 07-25-2020, 01:56 AM
Last Post: Brad14_imp
  Fuel Tank Removal Gabby_imp 11 948 06-19-2020, 10:54 AM
  Canister removal Feelergaugephil_imp 2 322 10-11-2019, 10:59 PM
