07-22-2020, 05:30 AM
I had puncture yesterday, lucky me, so out came the rear wheel and wow how heavy is this wheel!!, I had to weigh it 50lb!!!
Wheel weight
07-22-2020, 05:45 AM
Wow! From taking mine off I knew it was heavy, but that’s just crazy.
07-22-2020, 05:55 AM
Rear wheel with sprocket, rubber cushions, disc carrier, disc rotor, speed sensor ring, tube and tire?
07-22-2020, 05:57 AM
Now we all know where that 544 lbs is hiding
07-22-2020, 06:20 AM
Ferret this the RS model so alloy....steel alloy
07-22-2020, 10:14 AM
That sounds high! Was there water dribbling out of the leak?
07-22-2020, 02:11 PM
07-25-2020, 01:56 AM
Yup scall is used to weigh bikes for setup. Its bang on
« Next Oldest | Next Newest »
| Front wheel bearing noise? | MagnaRider | 20 | 1,685 |
03-31-2026, 08:20 AM Last Post: peterbaron |
| This is why wheel bearings are failing | 1973cb750 | 3 | 335 |
02-05-2026, 08:11 AM Last Post: 1973cb750 |
| CB11OO EX wheel rims | sprint | 6 | 626 |
02-26-2025, 06:16 AM Last Post: Cormanus |
| Wheel sensors | The Gecko_imp | 48 | 3,827 |
07-27-2023, 03:51 AM Last Post: The Gecko_imp |
| Weight limit on genuine Honda rear rack | DaveP_imp | 14 | 1,189 |
11-17-2022, 02:57 AM Last Post: GoldOxide_imp |
| 2013 replacement wheel | Randy B | 8 | 762 |
11-13-2022, 10:32 AM Last Post: Randy B |
| wheel imbalance | j3gq_imp | 7 | 617 |
07-03-2022, 09:35 AM Last Post: GoldOxide_imp |
| Easy bar end weight removal | brian10x_imp | 6 | 612 |
06-06-2022, 01:04 AM Last Post: 1973cb750 |
| Kink in rear (spoked) wheel | Ayrshire Dunx_imp | 1 | 251 |
04-09-2022, 09:37 PM Last Post: GoldOxide_imp |
| Friction front wheel | j3gq_imp | 12 | 883 |
12-12-2021, 01:26 PM Last Post: jimgl3_imp |
