Threads: 3
Hi,
Has anyone removed the stock canister?
I ask, because I had a BMW K1200 and the canister was a big issue with back feeding the gas tank and contaminating the fuel pump then fuel pump failure..
Just wondering if anyone here has disconnected it..
THX.
Threads: 27
(10-11-2019, 02:40 PM)Feelergaugephil_imp Wrote: Hi,
THX.
Hmmm.... I thought the vapor from canister goes into airbox, not returning back into tank.
Likes Given: 141
You are mostly correct Zirconxi. Vapors in the tank are gathered by the EVAP Canister. When the EVAP purge control valve is open vapors are drawn into the Throttle Body. There is a drawing and explanation of this in the service manual.
