Fuel Tank Removal
Hello. I have read the posts on fuel tank removal and still have a question please. My bike is a 2017 CB1100RS. When I dis-connect the fuel line will it seal itself or do I have to drain the Tank first. Any help much appreciated.
2013 model auto stop fuel from coming out. So i guess 2017 should be the same.
Upon fuel line disconnection will not leak (2013-17)
Best option: pull out fuel pump relay or disconnect fuel pump connector, started and let it run until dies.
When everything back together, turn on/off ignition 2x to prime the fuel system, then start.
Good luck with safe procedure.
Thanks for the replies. That helps.
PM me with your email and I will send you a picture of the fuel pump connector.
Which white ab to press in order to release the fuel line connector.
As PB mentioned, ran the engine until it stall.
I took a great shot the last time I remove my 17' EX fuel tank.
Hi Alain, I'm going to change out my tank soon also. Could you also send me your pics, or is the 2017 different?
Amos , do you need the 2014 manual , I have one here you can borrow.
Thanks, but yes, I have one. Just looking for all the info I can get.
(06-17-2020, 08:49 AM)The A-man_imp Wrote: Hi Alain, I'm going to change out my tank soon also. Could you also send me your pics, or is the 2017 different?
Please PM me with your email address.
File size is too big to post
Regards
Alain
Some time ago, these were posted by MAX:
https://www.youtube.com/watch?v=h28OQoUmHwY
https://bikesandtravels.com/biker.aspx?ride=982
And here is the entire thread "Tank fun"
http://cb1100forum.com/forum/showthread.php?tid=12870
Good luck, play safe with fuel.
Beer
  Valve Adjustment and Camshaft Removal dave 5 638 03-21-2026, 04:49 PM
  CB1100RS fuel tank rust Narciso 12 1,416 09-27-2025, 02:06 PM
Last Post: tdbru
  Left side cover removal jeffmazz_imp 24 2,214 07-09-2025, 03:37 PM
Last Post: bflint
  CB1100 fuel tank upgrade johnnyH_imp 3 460 03-13-2024, 01:31 AM
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 6,365 07-25-2022, 06:54 AM
  Easy bar end weight removal brian10x_imp 6 625 06-06-2022, 01:04 AM
Last Post: 1973cb750
   Resistance of Fuel Tank 2014CB1100 itsok_xman_imp 7 688 04-01-2021, 02:34 AM
Last Post: itsok_xman_imp
  Fuel tank interchangeability? Model difference questions.... 2014ltdltz 5 737 10-12-2020, 11:59 PM
Last Post: 2014ltdltz
  Air box removal ACE_IRA_imp 23 1,726 09-25-2020, 05:56 AM
Last Post: ACE_IRA_imp
  How to empty the fuel tank? Ulljanrich_imp 23 1,945 07-20-2020, 04:45 AM
Last Post: TXBikerGuy
