Torque values for sprockets
Anyone have the torque value for the front and rear sprockets? I have a 2014 standard and will be changing to 17/43 and will need to torque these badboys back down appropriately.
Also is there a how to on changing the rear sprocket? I think i can figure it out but just in case its always nice to see if someone else has done it.
Thanks,
Jermo
Rear wheel driven sprocket nut (quantity 5) 80 ft lbs.
Drive sprocket bolt (quantity 1) 40 ft lbs.
(08-17-2017, 08:52 AM)Lord Popgun_imp Wrote: Rear wheel driven sprocket nut (quantity 5) 80 ft lbs.
Thanks Popgun!!!
For the rear, the book says remove the nuts and driven sprocket from the driven flange. Thats easy.
For the front, see your PM in a few minutes.
I recommend loosening and tightening/torquing the rear sprocket bolts while still on the bike, otherwise you will be applying a lot of torque and the wheel will move about unless someone else holds it.
Stand on the right side of the bike, put your foot on the rear brake, and loosen the nuts. Same to tighten/torque them.
For the front sprocket, put it in gear and stand on the rear brake.
(08-18-2017, 02:17 AM)pekingduck_imp Wrote: I recommend loosening and tightening/torquing the rear sprocket bolts while still on the bike, otherwise you will be applying a lot of torque and the wheel will move about unless someone else holds it.
Thanks Peckingduck! I got the rear sprocket in the mail yesterday and the front will be here today so I will probably toss them on there tonight. super excited! Ill let you guys know how it turns out.
Got it done on friday night and went riding around 300 or a little more miles this weekend. 17 front, 43 rear on the 2014 is the sweet spot according to my likings.
Thanks all for the assistance.
  Center stand and new chain / sprockets jermo47_imp 8 848 04-24-2024, 10:55 PM
Last Post: jermo47_imp
  Torque value question Jonnyteabag_imp 9 639 03-10-2023, 01:00 AM
Last Post: 1973cb750
  Milage when replacing chain and sprockets Frulk_imp 8 609 02-11-2023, 03:29 PM
Last Post: Frulk_imp
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 642 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 394 04-03-2021, 01:35 AM
  Engine mount bolt torque value TCinNC_imp 43 2,537 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Steel Rear Sprockets johnnyj_imp 29 1,746 04-27-2020, 10:48 PM
Last Post: jimgl3_imp
  Chain and Sprockets - O My! Mandrau_imp 1 223 09-06-2019, 12:26 AM
  16 front 45 rear sprockets jermo47_imp 24 1,653 06-09-2019, 12:17 PM
Last Post: 17-CB-002
  Shock bolt torque HBFL_imp 9 679 04-11-2019, 07:04 AM
