16 front 45 rear sprockets
I have a 2014 and I feel the gearing is too long, especially 1st to 2nd. I was playing with gearing commander and looking around online and found a couple sets, 17/43, 17/45 and a 16/45 and was wondering if anyone has geared down their 2014+ bikes?
95% of my riding (commuting to work) the speed limit is 60 so 3200 rpms in 6th feels like its just lugging it and I find myself in 3rd and 4th gear most of the time, up to 75 mphs, grabbing 5th on occasion as well but rarely do I actually use 6th gear. there will be some trips over to idaho/utah which will have me up in the 90mph range but being that the majority of my riding is local backroads or 60 mph freeway I feel this change would suit me well.
Anyone done this? Anyone know if I would need to get a longer chain? Worried a little about going up 5 in the back but not sure about how much larger it is in reality.
Thanks!
I am thinking the same thing with my 2014 Standard. From what I have read here, there is room on the stock chain for up to three additional teeth on the rear sprocket and of course no issue with fitting a smaller front. Some have expressed concern with increased chain wear from a smaller front sprocket but, I'm not to worried about a one tooth drop. There was one poster here that was not happy with the added vibration from the smaller front sprocket but others that had no issue with it. I did run some numbers to see the effect from a percentage of change in ratios basis just to gauge the differences:
Front Rear Ratio Delta
18 40 0%
18 42 +4.76%
18 43 +6.98%
17 40 +5.56%
17 42 +10.05%
17 43 +12.14%
I didn't want to go to radical and am considering adding two teeth to the rear. If that does not get me where I want to be, I can always take the front down a tooth. There are a lot of posts regarding dropping rear and adding front teeth for the 5 speed bikes and a few regarding what we are contemplating. Caddy425 just posted that he was happy with a one tooth drop on the front. Django had thoughts on the same. Beardyweirdy went with 17/43 and loves it. But his bike has many other performance upgrades to go with it.
So, as with everything else, you'll only know when you try it!
When i was on gearcommander earlier it looked like 17/45 was nearly the same as 16/43. since it looks like going with a 45 on the back may pose issues, dropping 2 on the front and adding 3 on the back might just get me where i want to be. The cbr1000rr come stock with a 16/42 setup on a 530 chain like ours so I dont think dropping 2 would be too much of an issue, and worst case i wont be able to get the ferrets 20k+ miles out of a chain. Front sprockets are pretty inexpensive though so if im not super happy with the 16 front i can slam a 17 on it and end up at 17/43.
Amazon link to the 17/43 kit:
https://www.amazon.com/gp/product/B00U6H...8QEV615KIH
the 16 tooth front:
https://www.amazon.com/gp/product/B000GT...PDKIKX0DER
Thanks for the links, didn't know Amazon had them as kits. Please let us know how it works for you.
I dropped a tooth on my front sprocket and changed to 17" wheels which had a similar effect to increasing the rear sprocket a little. I absolutely love it. I spend way more time riding twisty mountain roads than I do cruising or interstate riding so I don't mind the extra rom's it takes to cruise at highway speeds. The acceleration increase is definitely noticeable and a lot of fun.
(08-14-2017, 08:07 AM)jermo47_imp Wrote: When i was on gearcommander earlier it looked like 17/45 was nearly the same as 16/43. since it looks like going with a 45 on the back may pose issues, dropping 2 on the front and adding 3 on the back might just get me where i want to be. The cbr1000rr come stock with a 16/42 setup on a 530 chain like ours so I dont think dropping 2 would be too much of an issue, and worst case i wont be able to get the ferrets 20k+ miles out of a chain. Front sprockets are pretty inexpensive though so if im not super happy with the 16 front i can slam a 17 on it and end up at 17/43.
the 16 tooth front:
I was concerned with the sprocket kits on Amazon fitting the 2014. I asked and this is the response.
[Image: 9d91a9562b70d1df590458920f9cc639.jpg]
Hmmmm, just noticed he said CB1000, not CB1100. I'll ask again. Sorry about that.
From what i have gathered the wheels and front sprocket are the same between the 2013 and the 2014+. since the wheels are the same, the sprocket made for the 2013 should fit all years. the only thing i would be worried about would be the 2014+ delux with their wire spoke wheels but again, no reason for honda to design a different sprocket mount for the rear wheel there.
I will probably end up going with the 17/43 as it will still fit the stock chain and then pick up a separate 16 front for if i want to drop the gearing further. the 16/43 was right about the same as the 17/45 on gearcommander. When i get these I will let you guys know.
Thanks
For the front sprocket, afaik Honda has the same build for a lot of models.
E.G. the 17 sprocket OEM part# 23801-MAT-760 from the 1999 Honda Super Blackbird CBR1100XX fits perfectly to a CB 1100.
http://www.bikebandit.com/oem-parts/1999...#sch100684
May be, the 16 sprocket from another Honda model would also fit to the CB 1100.
I ordered the 17 and 43 tooth sprockets and will toss them on either tonight (if they arrive today) or tomorrow night. I went with a 43 in the rear because it looked like the 45 wouldnt fit with the current chain and id rather not have to buy a new chain right now.
(08-17-2017, 03:36 AM)jermo47_imp Wrote: I ordered the 17 and 43 tooth sprockets and will toss them on either tonight (if they arrive today) or tomorrow night. I went with a 43 in the rear because it looked like the 45 wouldnt fit with the current chain and id rather not have to buy a new chain right now.
JMo, have you been able to install and ride yet? I'd really like to know it worked out for you. Thanks!
  Center stand and new chain / sprockets jermo47_imp 8 847 04-24-2024, 10:55 PM
Last Post: jermo47_imp
  Rear only tire on the front? mattmcuomo@yahoo.com 5 554 10-09-2023, 06:05 AM
  Milage when replacing chain and sprockets Frulk_imp 8 606 02-11-2023, 03:29 PM
Last Post: Frulk_imp
  How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013 pekingduck 60 3,936 03-07-2021, 09:32 PM
  Steel Rear Sprockets johnnyj_imp 29 1,736 04-27-2020, 10:48 PM
Last Post: jimgl3_imp
  Chain and Sprockets - O My! Mandrau_imp 1 219 09-06-2019, 12:26 AM
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,541 09-14-2018, 12:35 AM
  Deciding 37 vs 35 tooth rear sprocket on 2013, 19 on Front is correct rbike_imp 41 2,679 09-01-2018, 03:19 AM
Last Post: IndianRider_imp
  New Rear Tire and Rear Brake Pads memphismike_imp 5 523 06-11-2018, 09:35 PM
  Torque values for sprockets jermo47_imp 6 539 08-21-2017, 06:41 AM
