Chain and Sprockets - O My!
Greetings to the forum.
The original chain on my 2016 CB1100 standard is almost stretched out after 50,000km. Thinking of replacing it with a DID ZVMX x-ring. Pitch 530/Links 110. Hope I got that right because it seems to come only with 120 links on various online websites. As for sprockets, my understanding is that the stock front is 18 and rear is 40 tooth whereas the stock rear sprocket on a 2013 CB1100 is 39 tooth. I would like to install a 39 tooth in the back and a 19 tooth on the front to tallen up the gears a bit. Anyone know if the 39 tooth stock rear sprocket on a 2013 would fit on a 2014+ standard CB1100? Also, where to get a 19 tooth front?
Am I on the right track before I start ordering stuff online?
Cheers...
I bought my three DID ZVMX silver plated chains from : Sprocket Center , very pleased with them and they could help you getting the right length. I stayed with the standard 110 links and did not change the sprockets (still in very good order as I went to new chain very early )
I also bought the DID KM500R Professional Chain Rivet and Cutting tool.
Probably other GOOD ! tools will also work , do not buy cheap ones as they often fail quickly.
  Center stand and new chain / sprockets jermo47_imp 8 890 04-24-2024, 10:55 PM
Last Post: jermo47_imp
  Milage when replacing chain and sprockets Frulk_imp 8 651 02-11-2023, 03:29 PM
Last Post: Frulk_imp
  Steel Rear Sprockets johnnyj_imp 29 1,868 04-27-2020, 10:48 PM
Last Post: jimgl3_imp
  16 front 45 rear sprockets jermo47_imp 24 1,777 06-09-2019, 12:17 PM
Last Post: 17-CB-002
  Torque values for sprockets jermo47_imp 6 573 08-21-2017, 06:41 AM
  Getting ready for new chain and sprockets the Ferret 8 598 07-30-2017, 07:39 AM
   Warning 7th Gear Designs Sprockets rbike_imp 26 1,701 01-16-2017, 06:20 AM
Last Post: IndianRider_imp
  JT Sprockets chain sold on Amazon kennyw 3 324 06-02-2016, 12:53 AM
Last Post: kennyw
  Sprockets, sprockets, sprockets. Pterodactyl_imp 18 1,030 06-23-2015, 09:30 PM
Last Post: Django
  Chains and Sprockets OldF7Guy_imp 37 2,485 08-22-2014, 03:43 AM
Last Post: flynrider
