Milage when replacing chain and sprockets
I’m around 22,000 miles on the 2013 and am wondering when you guys ( and possibly gals) started to replace your sprockets and chains. I figure I might as well do it all at once if I’ve met that milage cap where it should be done.
I did mine at 37,000 chain, sprockets and rubber cushions but don't think it really needed the rubber cushions. I'm now at 32,500 approx on the replacement set (OEM parts)
I did my first replacement of both chain and sprockets at 30,000 miles. Either the second chain was faulty or I damaged it somehow, but I had to replace it (and the sprockets) after 16,000 miles. That replacement lasted 27,000 miles and probably had a little more life in it.
I don't think the rubber bits have ever been changed.
I replaced everything/OEM, front & rear sprockets, chain and rubber dampers at 41K miles.
The chain was at max stretch , had few kinks, front & rear sprockets had minimal wear, but rubber dampers were almost perfect/like new.
Due to chain kinks, my bike had a vibration in 4th gear/lower speeds
The chain received average service.
The sprockets would easy go to 60K miles but did not want to do half a maintenance = twice, so did everything at one shot. No regrets.
Here are some pics, judge yourself.
[Image: cc96244ec0d6c1c34bab06ce407fb6f2.jpg]
[Image: 1651d302b7de349d747935f508161a88.jpg]
[Image: 2f630b2fc84f2fe1c1ce5b7d5294a1df.jpg]
36,000 miles. Replaced with DID x ring chain and standard size sprockets.
30,067 miles. Replaced chain and sprockets. The sprockets looked good, but the chain developed a tight spot. I am disappointed with the mileage I got out of this chain because I cleaned and lubricated my chain regularly. I would clean my chain with a wire brush, wipe it clean with WD-40, blow all the WD-40 off with a high-pressure air hose before lubricating it with Chain Wax approximately every 3,000 - 4,000 miles. I would lubricate it approximately every 500 miles, or less. I've tried various brands of chain lubricant, and I can't really say I've noticed any better performance from one compared to another. Maybe I've just opened up a good conversation topic concerning chain lubricants, because I've known people to have very strong opinions when it comes to chain lube, just like they do concerning motor oil.
(02-11-2023, 01:27 AM)Dave_imp Wrote: 30,067 miles. Replaced chain and sprockets. The sprockets looked good, but the chain developed a tight spot. I am disappointed with the mileage I got out of this chain because I cleaned and lubricated my chain regularly. I would clean my chain with a wire brush, wipe it clean with WD-40, blow all the WD-40 off with a high-pressure air hose before lubricating it with Chain Wax approximately every 3,000 - 4,000 miles. I would lubricate it approximately every 500 miles, or less. I've tried various brands of chain lubricant, and I can't really say I've noticed any better performance from one compared to another. Maybe I've just opened up a good conversation topic concerning chain lubricants, because I've known people to have very strong opinions when it comes to chain lube, just like they do concerning motor oil.
Pop on a [url=https://www.tutorochainoiler.com/]Tutoro auto oiler (or decent equivalent) and you may get your 60000 chain range. There are a few searchable posts in this forum.
I wipe the chain maybe twice a year with a stroke of a rag. Never had to replace sprockets or chains. I really dislike bothering with chains, so this seems to work.
In any case, I did it mostly to prevent the chain from turning orange in winter due to exposure to road salt. In all cases, I continued to use those "orange" chains as the oil slowly restored their (** cough **) beauty.
I use Motul cleaner and lube. I’ve always been reasonably good with cleaning and lubrication; cleaning every 500 mi and light lube every other ride. I could have gotten about another 3 or 4000 miles out of the original chain, but we had a lot of rainy days on weekends so I had some down time.
Thanks for all the replies. Will hold off to 30,000 miles unless something happens before that.
  Center stand and new chain / sprockets jermo47_imp 8 848 04-24-2024, 10:55 PM
Last Post: jermo47_imp
  Question on replacing engine side cover Ollie 11 763 01-10-2022, 11:21 AM
Last Post: Ollie
  Replacing Wheels - Manual Instructions Ludicrous jasonsargonautalis_imp 12 1,209 12-11-2021, 08:52 AM
Last Post: jimgl3_imp
  Steel Rear Sprockets johnnyj_imp 29 1,743 04-27-2020, 10:48 PM
  Chain and Sprockets - O My! Mandrau_imp 1 221 09-06-2019, 12:26 AM
  16 front 45 rear sprockets jermo47_imp 24 1,653 06-09-2019, 12:17 PM
Last Post: 17-CB-002
  Replacing turn signal bulb on a 14. the Ferret 7 476 04-24-2019, 01:33 AM
Last Post: Rocky_imp
  Replacing Left Side Engine Cover will866_imp 4 350 03-29-2018, 10:36 AM
Last Post: jeffmazz_imp
  Torque values for sprockets jermo47_imp 6 542 08-21-2017, 06:41 AM
  Getting ready for new chain and sprockets the Ferret 8 567 07-30-2017, 07:39 AM
