Throttle Tamer install
TINK_imp Offline
Threads: 36
I installed a G2 Throttle Tamer, here's how I did it...
Remove bar end, hand grip and switch housing screws.
Because the throttle cable length prevents you from simply sliding the throttle tube straight off,
you will need to remove the bars in order to remove/install the throttle tube.
Simply slip the OEM throttle tube out of the switch housing and remove the cables.
The G2 Throttle Tamer cam is larger than the OEM.
Getting the larger G2 Throttle Tamer cam to slide back into the switch housing is a little tricky without loosening the cable adjustment at the throttle body,
but it can be done with a little manipulating, but its tight.
Reinstall throttle tube, switch housing screws, hand grip and bar end... go for a test ride.
TINK
To: "'Brian \"TINK\" Tinkler'" <tinkler@xxxxxx.com>
Subject: RE: Honda 2014 CB1100 G2 Street Tamer?
Date: Oct 13, 2014 7:16 AM
Yes, it just isn't listed. Sorry about that!
Here is the link and model to order (same as ST1300):
http://www.g2ergo.com/store/g2-street-ta...ttle-tube/
Thanks!!
Gary
-----Original Message-----
From: Brian TINK Tinkler [mailto:tinkler@xxxxxxx.com]
Sent: Saturday, October 11, 2014 7:58 PM
To: street.tech@g2ergo.com
Subject: Honda 2014 CB1100 G2 Street Tamer?
Can you tell me if there is G2 Street Tamer for the 2014 Honda CB1100. please, thanks.
Brian "TINK" Tinkler
10-25-2014, 08:29 PM
redbirds_imp Offline
Threads: 186
RE: Throttle Tamer install
Thanks Tink. Great narrative and pics.
10-25-2014, 10:33 PM
Rocky_imp Offline
Threads: 26
Interesting, and maybe I'm missing something, but what's being gained with this mod?
Never mind, I did an online search and see what's it about.
The throttle on my CB is very smooth and progressive with no jerking or snatching at all, so I'm staying with the OEM.
Looks like a great mod for those who need it.
10-26-2014, 01:45 AM
Likes Given: 799
Moved to the How to Section
Thanks Tink!
10-26-2014, 05:57 AM
Gumby 1100_imp Offline
Threads: 17
Tink,
Throttle Free-Play is adjusted right where the cables enter the switch housing. That being the case, couldn't you have simply created enough slack at that point to make disassembly and reassembly easier without the need to remove the bars?
I went through a similar process on my Vulcan 1700 and did not need to remove the bars. You just need to readjust your throttle free-play afterwards, and marking the fittings before hand makes this simple.
Now, perhaps the cables on my Vulcan were much longer to begin with, but the cable adjustment hardware at the switch housing looks very similar.
10-27-2014, 01:44 AM
  Anyone using the Kaoko throttle control? milkmaster_imp 50 3,467 07-12-2023, 06:45 AM
Last Post: milkmaster_imp
  Windjammer ss. Install caddy425_imp 15 1,382 03-29-2022, 01:28 PM
Last Post: Canadianredneck_imp
  Puig Plus install question Rolls_imp 16 1,335 01-24-2022, 04:33 AM
Last Post: j3gq_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,377 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Honda top case install Jonnyteabag_imp 11 944 12-31-2021, 09:22 AM
Last Post: Jonnyteabag_imp
  2017 CB1100EX Clearwater Darla Lights Install TXBikerGuy 7 678 07-25-2020, 08:51 AM
Last Post: TXBikerGuy
  tail-bag install Chuckk_imp 6 642 11-19-2019, 05:49 AM
Last Post: IndianRider_imp
  Help! Dynojet PC V Install Not Going Well, 2014 CB MinkeyChief_imp 3 425 11-05-2019, 03:53 AM
Last Post: MinkeyChief_imp
  Left over part from TSR Intake and Funnel install?? teamvisegrip_imp 5 544 09-21-2019, 10:48 AM
Last Post: teamvisegrip_imp
  Auxillary USB Power Plug install for IPhone Frulk_imp 22 1,357 05-12-2019, 06:00 PM
Last Post: Bazbro_imp
