2017 CB1100EX Clearwater Darla Lights Install
TXBikerGuy Offline
Threads: 9
I've been a fan of Clearwater lights since I put my first set of Darla's on my 2014 BMW K1600GTL. Put my 2nd set on the KTM 1190 Adventure and now, the 3rd set is fully installed on the '17 EX. Posting some pics of the process in case anyone else is thinking about adding these in the future.
I chose the universal fender mount/location in part because I like having the ability to direct the beams by turning the handlebars. The can also be mounted easily on engine guards--particularly the SW Motech bars as they have a nice crossbar almost custom-made for lights.
The wiring runs nicely up along the brake lines. This is the R side light.
Wiring continues into the opening along the side of the frame under the fuel tank on both sides. (I removed the tank to make the wiring install easier)
This little pocket area worked out perfectly as a spot to collect the wires from the lights, controller knob and power relay. It would have been a much cleaner install if I'd have cut all the wires to just the length needed for this bike. But, at $550 a set--I want to retain the ability to take these off this bike if/when I sell it to use on the next bike. So, I accepted a little "rat's nest" look as a result. I hope I don't lose too much credibility here for that. Smile
Apparently, I've reached the limit of photos for a single post so I'll stop this one here and start a new one to finish up. Coming up...leads to the battery control knob and inside the headlight shell.
07-24-2020, 07:29 AM
peterbaron Offline
Likes Given: 996
RE: 2017 CB1100EX Clearwater Darla Lights Install
Neat and like a professional job/installation = Thumbs Up
07-24-2020, 07:31 AM
Ennsync_imp Offline
Threads: 13
excellent work of art and your self and clearwater.
07-24-2020, 07:39 AM
TXBikerGuy Offline
Threads: 9
I ran the leads to the battery down the right side of the frame. Will be obscured by the tank. The fuse is accessible behind the right side cover. In hindsight, I wish I'd have put these wires in some casing. Would have looked cleaner.
Here's where I mounted the controller knob. I wanted to be able to adjust the brightness with my left hand and not have to reach across the bike.
As discussed in a different thread about the headlight wiring, the default mode for this controller is to tap into the low-beam wire for power (#8 position on the LED plug) and into the high-beam wire so the lights switch to 100% brightness when the high-beams are activated. They are set to only go to 55% brightness using the knob in the low-beam only mode. Unfortunately, the '17 LED headlight is wired so the high-beam wire has power all the time (ground switched). Not wanting to experiment with tapping into other wires in a $1000 piece of equipment, I opted to reprogram the controller to allow for 100% brightness without the high-beam connection.
Pro Tip from Clearwater. Start with all power off to the lights and controller. Have the controller knob all the way to the left. Turn on the power to the lights and controller and within 3 seconds, turn the knob all the way to the right--repeat 4 times so it stops on the right side. Lights should flash twice. You've reprogrammed the controller.
Here's the red power light tapped into the headlight plug.
07-24-2020, 07:46 AM
Likes Given: 1,011
Nice work, TXBikerGuy. Thanks for the write up.
07-24-2020, 09:07 AM
Redbird_imp Offline
Threads: 7
Very nice installation and a good write up.
Moderators: Consider moving(or copying) this to the How To section.
07-24-2020, 09:27 AM
17-CB-002 Offline
Threads: 45
Just wondering ....
Are these lights "Spot" or "Flood" pattern?
What type of projection on the road at night?
Thanks
Alain Lee
07-25-2020, 08:30 AM
TXBikerGuy Offline
Threads: 9
(07-25-2020, 08:30 AM)Alain Lee_imp Wrote: Just wondering ....
Thanks
Alain Lee
Here's what Clearwater says about them. My personal experience riding at night with them is that they significantly improve overall lighting visibility for me, so I consider them both safety features for daytime and helpful augmentation of the OEM headlight at night.
"We consider Darlas to be a combination of a fog and visibility light; however, due to the adjustable “dimming” feature, they serve multiple purposes. These lights are primarily for conspicuity (visibility to other motorists) rather than "down the road" illumination. Some customers have commented that even in bright sunlight, cars move over in front of them during their daily commute, whereas before our lights, they were constantly ignored. I find the car pool lane here in CA rarely has a car ignoring my approach from behind.
Although illumination is not the primary function of the Darlas, they will illuminate road signs, reflectors, and deer retinas much better than standard or halogen lights due to the higher bandwidth of light energy. You might be amazed at how far away exit signs can be seen."
07-25-2020, 08:51 AM
  2017 OEM CB1100EX/RS Accessory Brochure rdprdp01 0 334 04-16-2025, 02:05 AM
Last Post: rdprdp01
  Additional front driving lights Davidjill_imp 6 658 08-28-2024, 12:46 PM
Last Post: michael1954
  16,000 Lumens Spot Lights to complement 2017 Led headlights 17-CB-002 51 4,265 04-23-2024, 07:31 AM
  2017 CB1100EX Color matched side covers ceeko_imp 66 4,291 06-25-2023, 10:17 PM
  Windjammer ss. Install caddy425_imp 15 1,348 03-29-2022, 01:28 PM
Last Post: Canadianredneck_imp
  Puig Plus install question Rolls_imp 16 1,309 01-24-2022, 04:33 AM
Last Post: j3gq_imp
  CRG Bar end mirrors for 2017 CB1100ex Senna02_imp 5 593 01-20-2022, 06:47 AM
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,369 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Honda top case install Jonnyteabag_imp 11 913 12-31-2021, 09:22 AM
Last Post: Jonnyteabag_imp
  QD exhaust for CB1100EX twin muffler arata194_imp 2 338 07-11-2021, 09:02 PM
