Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue!
rdtshaw_imp Offline
Threads: 5
Hi All!
Okidoki, my first post on the mod's section here and my first mod on my CB. I picked up a Yoshimura RS-3 slip on in stainless for $280 shipped. Sweet deal from indysuperbikes.com and they were really helpful on the phone as I was trying to get it shipped to CA before the weekend. They called Yoshimura in So. Cal. and had it drop shipped that day. Now, that said I made a mistake on the one I purchased. If you just google the RS-3 for CB1100, there will be a number of vendors that list it as fitting 2013-2014 CB1100 with single exhaust. This is not the case, as the center stand adaptor that ships with the 2013 kit does not work on the 2014, standard or deluxe. When you remove the factory exhaust, it takes the travel stop for the center stand with it that is welded to the factory exhaust pipe. Without it your chain becomes the travel stop. Nifty bit of engineering on Honda's part, not so helpful if you want to upgrade your pipe. So to compensate for this, Yoshimura includes an adaptor bracket that slides over the stock center stand hinge point that serves as a stop, even better that the stock one I think. That said, Honda moved the return spring assembly on the 2014 to the center of the center stand from where it was on the side on the 2013. (to accommodate the dual exhaust on the deluxe I'm assuming?). This makes the adaptor plate interfere terribly with the spring assembly.
It is a bit of a bear to put on the bracket and slide the 2 little elusive $#@% spacers between the bracket and the frame. I was lying on the ground for the better part of 45 mins trying to get them in and the whole time my shoulders were screaming, WTF is this messed up angle you're working at??? Smile I finally got it bolted up and pulled the bike of the center stand to test it out and it just goes up about 2 inches and binds. Super nice. Angry At this point I get on the web and found another member here on CB1100 that had the same issue to no avail, it looks like he dumped his stand. I had already installed everything, so no returns. I went to Yoshi's site and sure as shinola there are two different part numbers for the 2013 and 2014 and the 2014 version mentions nothing about the nifty center stand adapter they include with the 2013. I had hoped I could order the proper bracket from them, all other posts I found about issues with their systems seem to be well supported and handled by their support team. Unfortunately it looks like they do not have one available. I was pretty thrilled with the center stand and a lot of maintenance in the service manual starts with, "Place the bike on the center stand on a level surface and check the level of ..." Anyhow, long story short I was able to modify the bracket and it worked out well. And it doesn't look *too* shody. The exhaust itself went on smooth, zero issues. Bolted right up with no exhaust leaks. It sounds really good! I added a K&N too and it jumps when I roll the throttle. Did I mention how good it sounds? So here's the required pics and details on the adapter plate modification I did in case anyone else runs into this bit of fun. Hope there not too many pics and they make sense. Thumbs Up Post about my new license plate holder fab up to follow.
I ended up cutting out the middle section of the adaptor plate. I mounted them on each side as per the instructions. It is still plenty strong, really strong, when it is mounted.
Cleaned up the cuts. Eased the corners on the grinding wheel and filed it all down smooth.
I brushed on a couple coats of black enamel to keep the freshly cut steel from rusting. Delay it anyhow, I live 1/4 mile from the ocean: Death, taxes, and rust.
Ready to install! I picked up some stainless bolts and a nylock nut to replace the zinc coated ones and the regular nut they included. No split washer or anything? weird. Fixed that up.
Here is the plate installed and doing it's job. It's twin looks the same on the other side.
Here is how the spring assembly sits in the middle with the plate I cut up on either side. This should make a bit more sense seeing it.
It only has to support the tension on the return spring and maybe an occasional slap of the center stand coming up. The bracket they supply is WAY overbuilt. Considering the way it is sandwiched in the rolled up side of the frame and how it cantilevers against the frame when the stand is resting against it with no side load on the bolt; I can't see how it would fail. You seeing this Yoshimura folks?? Tongue
09-13-2014, 02:59 PM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
RE: Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue!
You made what seems to be the classic mistake when installing an aftermarket can......
[Image: 3ded358fcece3fb9230bea1eb34fc360.jpg]
You are supposed to bolt it up on the back side of the peg plate, not the outside.
09-13-2014, 04:01 PM
rdtshaw_imp Offline
Threads: 5
No, I don't think so. According to the instructions, it is supposed to be on the outside and the strap is not shaped to hang the can off to the side. Also, it will not line up with the header correctly if I move it over and it will interfere really badly with the shock. That said it would look cleaner if it bolted from the back side. I would have to bend up the strap in my vise to get it to more of a "D" shape, but I'm pretty sure that will require more strap length than is available as it would have to pull away from the can to offset to one side. The opposite side would have to loop over the top and back up to line up the bolt holes...
09-13-2014, 05:03 PM
CIP57_imp Offline
Threads: 68
Job well done, share this with Yoshi and they'll make changes to the 2014 model bracket for future purchases. They are very easy to contact with great costumer service.
09-13-2014, 08:08 PM
Randy B Offline
Threads: 85
Likes Given: 133
I see. There was a different aftermarket muffler that someone installed (I think it was a Staintune) that does attach to the backside, but this one obviously does not.
09-13-2014, 09:18 PM
chrisross_imp Offline
Threads: 8
Thank you! I went so far as to cut a giant notch in mine to allow the c clip to pass through but the spring still got caught up. I had the thought of just going ahead and cutting the the thing in two pieces but I was afraid it wouldn't be strong enough.
Now I know exactly what to do to make it work! Which is a great thing because I dearly miss my center stand!
Thanks again
Chris
09-13-2014, 09:28 PM
rdtshaw_imp Offline
Threads: 5
(09-13-2014, 09:18 PM)Randy B_imp Wrote: I see. There was a different aftermarket muffler that someone installed (I think it was a Staintune) that does attach to the backside, but this one obviously does not.
Hey Randy, sorry I reread my reply. It sounds kinda dickish and I didn't mean for it to. "No, I don't think so..." I was late and I hit send with out proofing it for emotion. Smile Sorry about that, and thanks for the feedback!
Rob
09-14-2014, 03:08 AM
Randy B Offline
Threads: 85
Likes Given: 133
Rob
Rob
Meh...no big deal. You posted up the directions that came with it and explained to me the err of my ways very succinctly and I don't think you were rude at all.
Besides, it takes more than that on the internet to get my panties in a bunch. Beer
09-14-2014, 05:14 AM
rdtshaw_imp Offline
Threads: 5
(09-13-2014, 09:28 PM)chrisross_imp Wrote: Thank you! I went so far as to cut a giant notch in mine to allow the c clip to pass through but the spring still got caught up. I had the thought of just going ahead and cutting the the thing in two pieces but I was afraid it wouldn't be strong enough.
Thanks again
Chris
Hi Chris, my pleasure! I completely understand the frustration with this one. Smile Let me know how it turns out.
Cheers,
Rob
09-14-2014, 04:04 PM
Threads: 8
Thanks again
Chris
Cheers,
Rob
Cheers,
Rob
Rob,
Today is my day off and I've finally got time to tackle this project. Before I do would you mind letting me know how everything has held up so far? Also, what kind of paint did you use? It looks factory
Chris
09-24-2014, 01:09 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 671 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Stand-alone ECU TTRacer_imp 2 304 02-22-2024, 01:58 PM
Last Post: TTRacer_imp
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 3,795 11-29-2022, 10:38 AM
Last Post: mrded_imp
  Dart flyscreen and a little Yoshimura stain magic 1985CB450_imp 19 1,855 10-24-2022, 04:12 AM
Last Post: 1985CB450_imp
  Advice - carry water bottle and side stand plate? 4 Paws_imp 41 2,646 07-23-2022, 06:02 PM
Last Post: rich_imp
  Windjammer ss. Install caddy425_imp 15 1,323 03-29-2022, 01:28 PM
Last Post: Canadianredneck_imp
  Puig Plus install question Rolls_imp 16 1,293 01-24-2022, 04:33 AM
Last Post: j3gq_imp
  Honda top case install Jonnyteabag_imp 11 902 12-31-2021, 09:22 AM
Last Post: Jonnyteabag_imp
  2014 CB1100 EX Seat Fit On 2013 and Older Bikes SUPERCRUZ_imp 36 2,176 06-05-2021, 08:14 AM
  Pit Bull Rear Stand Stichill 7 627 05-02-2021, 04:45 AM
Last Post: ampm7_imp
