Anyone using the Kaoko throttle control?
milkmaster_imp Offline
Threads: 5
Anyone using the Kaoko throttle lock on their CB1100? If so, care to share your positives and negative experiences?
06-03-2023, 06:43 AM
RE: Anyone using the Kaoko throttle control?
I didn't use one on the Honda CB1100, but I am on the Honda CRF1000.
For a throttle lock, its greatest strength is its ability to regulate throttle response. That is, if you are going over rough roads and your throttle arm/wrist is bouncing around, it can smooth out the control.
As for a lock, it works well. I feel it is reliable. It is also well-crafted and blends in very nicely with the design of the bike.
On the other hand, it is no substitute for proper cruise control. However, it was not meant to be. In addition, it takes a bit to get used to. It might be one of those farkles either you like or dislike.
06-03-2023, 06:56 AM
Threads: 5
Thanks yes I agree it is no substitute. Sometimes you just need to lock the throttle for a minute when something itches or as you say stiffen it up a bit on a rough road. Smile The Kaoko is a little pricey, looks well done. THX
(06-03-2023, 06:56 AM)GoldOxide_imp Wrote: I didn't use one on the Honda CB1100, but I am on the Honda CRF1000.
06-03-2023, 07:01 AM
Likes Given: 1,015
Milkmaster, have a search on the forum. Others have used them in the past.
For example http://cb1100forum.com/forum/showthread.php?tid=15542
06-03-2023, 07:34 AM
1973cb750 Offline
All Tuned Up
Edmond Oklahoma
Threads: 13
Likes Received: 79 in 49 posts
Likes Given: 45
i have one threw it in the trash junk it was threaded in wrong direction the throttle returning to close would unlock itself
Website Find Reply
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
Looks cool, im not sure how that works though ill have to watch a video.
How much do those cost?
06-05-2023, 02:11 AM
The basic function is turn the ring to stiffen or lock the throttle from turning. It causes the shaft to "expand" creating a friction surface inside the handlebar that impedes throttle rotation.
Undo the turning to loosen or unlock the throttle to resume normal freeform throttle behaviour.
06-05-2023, 02:35 AM
mvk24_imp Offline
Threads: 18
(06-05-2023, 02:35 AM)GoldOxide_imp Wrote: The basic function is turn the ring to stiffen or lock the throttle from turning. It causes the shaft to "expand" creating a friction surface inside the handlebar that impedes throttle rotation.
O that sounds better than the cheap palm press style ones. Whenever I'd hit a bump I'd "blip" the throttle. Didn't like that at all and stopped using it by the end of the first day of a trip I got it for.
I would give this style a whirl. Maybe I'll try the aliexpress version for 32$
06-05-2023, 02:37 AM
1973cb750 Offline
All Tuned Up
Edmond Oklahoma
Threads: 13
Likes Given: 45
mine would just unscrew and not hold anything
06-05-2023, 04:59 AM
Website Find Reply
mvk24_imp Offline
Threads: 18
mine would just unscrew and not hold anything Thank sounds @~*^ty, not the kind of thing you can use locktite in either I suppose.
Probably doesn't help that you're removing a bar end weights to install it either. Im sure the vibrations can contribute to it loosening
06-05-2023, 06:20 AM
  Handlebar control symmetry Uncle Sixer 17 1,730 08-07-2025, 05:24 AM
  What cruise control are you using for your CB1100? goldeneye_imp 51 3,468 11-16-2023, 12:26 PM
  KAOKO cruize control ozigoo 6 542 05-27-2020, 01:14 PM
Last Post: 17-CB-002
  CBR RR throttle bodies TrickyNicky089_imp 29 2,447 08-13-2018, 06:26 PM
Last Post: Bradders_imp
  That ugly round blank on the throttle body the_undecider_imp 85 6,341 01-12-2018, 08:29 AM
  Foot Control Relocation Kit reinie_imp 6 626 01-10-2018, 12:13 PM
Last Post: Nightengale_imp
  Kaoko Cruise Control Kit 17-CB-002 12 856 07-19-2017, 02:10 PM
Last Post: Nortoon_imp
  Quick Turn Throttle olekzap_imp 15 1,377 08-24-2016, 10:02 AM
Last Post: Ulvetanna_imp
  I got booted out of Twisted Throttle Chapomis_imp 13 1,252 04-14-2016, 09:35 PM
Last Post: Chapomis_imp
  Brake Away throttle control Razor 25 1,666 07-16-2015, 10:05 PM
Last Post: redbirds_imp
