Puig Plus install question
Rolls_imp Offline
Threads: 25
Just got my Puig Plus mini wind screen, model 4620H.
For those of you who've installed one, how did you mount Puig's metal bracket to the headlight?
Did you use the stock headlight screws and slip the windscreen's metal bracket in between the headlight bucket and the headlight mounting bracket or did you replace the headlight screws with the screws (and the little cylindrical spacers) supplied in the Puig's installation bag o screws?
Thanks in advance for any guidance from those who've done this already!
Rolls
07-25-2013, 01:10 AM
CB4ME_imp Offline
Threads: 183
RE: Puig Plus install question
I slipped the windscreen's metal bracket in between the headlight bucket and the headlight mounting bracket.
07-25-2013, 06:21 AM
Huladog_imp Offline
Threads: 23
I placed the Puig bracket on the outside of the headlight mounts, left the vinyl covering on the backside of the Puig bracket hoping it would help prevent marks on the headlight bracket.
Still got small marks on the headlight mounts so you may want to apply some protective tape on the headlight mounts first.
Then used the longer Puig supplied bolts with those long spacers between the bolt head and the Puig bracket. Not the prettiest solution but it works. If the look bothers you then you can get some shorter stainless bolts or something.
I would send you a photo but I replaced the Puig with a Road Comet fairing.
Aloha,
Huladog
07-25-2013, 06:30 AM
Rolls_imp Offline
Threads: 25
That sounds simplest to me. If that worked for you, that's what I'll try after work tonight.
Thx!
(07-25-2013, 06:21 AM)CB4ME_imp Wrote: I slipped the windscreen's metal bracket in between the headlight bucket and the headlight mounting bracket.
That's what I hope to do next. I really like the looks of the Road Comet and the aluminum mini fairing, too. But this is my 1st foray into wind protection of any kind, so I thought I'd dip my foot in with the Puig and see how I like a little less wind on my midsection.
Thanks, huladog.
So great to have the experience of two guys who've already tried mounting the exact screen I'm using in each of the ways I was considering attaching it. This forum is awesome.
(07-25-2013, 06:30 AM)Huladog_imp Wrote: I placed the Puig bracket on the outside of the headlight mounts, left the vinyl covering on the backside of the Puig bracket hoping it would help prevent marks on the headlight bracket.
Aloha,
Huladog
07-25-2013, 06:42 AM
pwyakjr@stny.rr.com_imp Offline
Threads: 1
I just received my puig plus today. it does look very good, just the right size. i'll be on the highway tomorrow i'll let you know how it works. I slipped it between the headlight and the mounting bracket. it worked and looks good. I used the original headlight bolts.
10-07-2013, 11:36 AM
Threads: 1
ran the highway to work today. much more comfortable ride with the puig. just the right size, you will still need a face shield or full face helmet though. attached pictures
10-08-2013, 09:57 AM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
Dang good looking fairing, where did you get it?
10-08-2013, 02:29 PM
Threads: 1
monsterparts.com
10-08-2013, 09:19 PM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Given: 7
Thank you sir. Worship
10-09-2013, 12:04 AM
thessler3_imp Offline
Threads: 7
Mounted mine between the headlight and headlight mounts. Works fine there. Make sure you put the pads between the shield and instruments.
03-09-2015, 07:37 AM
   to puig or not to puig (or, which Puig screens fit ?) j3gq_imp 53 3,673 05-30-2022, 04:13 AM
Last Post: j3gq_imp
  Windjammer ss. Install caddy425_imp 15 1,358 03-29-2022, 01:28 PM
Last Post: Canadianredneck_imp
  Puig Vision Windscreen Interceptor Pilot_imp 5 602 03-03-2022, 08:39 AM
  Puig now listing the CB1100 CB4ME_imp 8 680 01-24-2022, 04:34 AM
Last Post: j3gq_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,376 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Honda top case install Jonnyteabag_imp 11 936 12-31-2021, 09:22 AM
Last Post: Jonnyteabag_imp
  2017 CB1100EX Clearwater Darla Lights Install TXBikerGuy 7 667 07-25-2020, 08:51 AM
Last Post: TXBikerGuy
  tail-bag install Chuckk_imp 6 624 11-19-2019, 05:49 AM
Last Post: IndianRider_imp
  Help! Dynojet PC V Install Not Going Well, 2014 CB MinkeyChief_imp 3 419 11-05-2019, 03:53 AM
Last Post: MinkeyChief_imp
  Puig Windscreen Quality Skypilot_imp 13 974 11-01-2019, 11:43 AM
Last Post: MWV1500_imp
