Help! Dynojet PC V Install Not Going Well, 2014 CB
MinkeyChief_imp Offline
Threads: 2
Apologies if I've missed relevant threads, but I've searched and people seem to have had no issues with the PC V install. And the Dynojet video makes it look easier than two sips of G&T.
1) I really struggled to remove the "quick" release connector on the fuel tank. Also, I didn't realize that a couple of parts on the quick-release valve, once removed, need to be replaced. Is that an overabundance of caution in the service manual (as with the oil drain plug bolt) and I should be okay reusing the clamp and rubber washer? (I know they're not expensive, but another wait, which may be moot because of point 2, below.)
2) I just cannot find the room to route the PC V harness alongside the current wiring. The stock loom is so thick that I can't squeeze the PC V connectors under the left side frame to be able to run it along the fuel tank. I can't move the loom enough in any direction. Would I need to loosen the air filter box? It can't be easy nor recommended to remove the PC V connectors to route the harness?
[url=https://ibb.co/nk6xPsw][Image: 6cb3cb421d4c15185e1065e8706134d0.jpg]
11-04-2019, 07:50 AM
chync_imp Offline
Threads: 20
It’s been a while since I did that but I would remove or loosen whatever parts you need in order to route the wiring. I definitely never had to or considered removing the connectors from the wires. I think I found a tight spot to squeeze the connector throwing. Once it’s through the frame it’s easy to move the wires to a better suited location from where the connector fit if that makes sense. Patience and a little persuasion is all I used.
11-04-2019, 09:18 AM
Chuckk_imp Offline
Threads: 19
RE: Help! Dynojet PC V Install Not Going Well, 2014 CB
I know what you mean about that fuel disconnect.. I will stay away from doing that again for as long as I can.. here is a pic of my 2017 quick disconnect and how I re-installed it.. yours may be different.. but make sure you do it right.. there was a posting of one coming loose after it was re-installed..gas all over !! .. mine has 2 plastic clips that hold the connector on.. I used a plastic wire tie, folded over to "jam" if you will, onto the top of one of the plastic clips.. the plastic clip cannot yield and allow the connector to come apart unless that wire tie is removed first.. I'm not sure as to how cheap a new connector would be, referring to the parts you are supposed to replace on your 2014..
.[Image: 52324b0c1d3ccd36f87bba6c60f47127.jpg]
11-04-2019, 09:42 AM
Threads: 2
Thanks chnyc! Knowing that I didn't have other options helped me figure this out! The airbox needed to be loosened, and just a few mm of give was enough to get the connector started on its journey. The loom had more play than I first thought--I needed to be less delicate about the whole thing!
Chuckk, though the 2014 connector looks different, your photo helped me understand what that rubber ring is doing--thanks! I have the PC V connected now... am giving it a day before getting back to the tank.
Looking forward to it--I have a K&N filter to install as well. No doubt I'll find a way to make a meal of that as well.
11-05-2019, 03:53 AM
  Windjammer ss. Install caddy425_imp 15 1,353 03-29-2022, 01:28 PM
Last Post: Canadianredneck_imp
  Puig Plus install question Rolls_imp 16 1,319 01-24-2022, 04:33 AM
Last Post: j3gq_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,374 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Honda top case install Jonnyteabag_imp 11 926 12-31-2021, 09:22 AM
Last Post: Jonnyteabag_imp
  2017 CB1100EX Clearwater Darla Lights Install TXBikerGuy 7 664 07-25-2020, 08:51 AM
Last Post: TXBikerGuy
  tail-bag install Chuckk_imp 6 617 11-19-2019, 05:49 AM
Last Post: IndianRider_imp
  Left over part from TSR Intake and Funnel install?? teamvisegrip_imp 5 524 09-21-2019, 10:48 AM
Last Post: teamvisegrip_imp
  Auxillary USB Power Plug install for IPhone Frulk_imp 22 1,308 05-12-2019, 06:00 PM
Last Post: Bazbro_imp
  Yoshimura RS3 Exhaust Can install and review Frulk_imp 4 435 11-02-2018, 06:57 AM
  CB1100ex 2017 dynojet pc v Bradders_imp 1 287 10-16-2018, 08:07 AM
