tire pressure
#41
I agree that nitrogen in road going vehicles is a gimmick. Nitrogen is sold here as an 'upgrade' because it should result in longer periods between topping up the tyre pressure. The larger nitrogen molecule (when compared to the oxygen molecule) is slower at permeating the tyre carcas so therefore nitrogen stays in the tyre longer, 3 to 4 times longer. The motorist is then encouraged to check their tyres even less frequently!! This rather scientific paper explains in more detail: http://www.getnitrogen.org/pdf/graham.pdf
(04-21-2014, 01:36 PM)Aussieflyer_imp Wrote: I agree that nitrogen in road going vehicles is a gimmick. Nitrogen is sold here as an 'upgrade' because it should result in longer periods between topping up the tyre pressure. The larger nitrogen molecule (when compared to the oxygen molecule) is slower at permeating the tyre carcas so therefore nitrogen stays in the tyre longer, 3 to 4 times longer. The motorist is then encouraged to check their tyres even less frequently!! This rather scientific paper explains in more detail: http://www.getnitrogen.org/pdf/graham.pdf
+1
Ausieflyer,
I read that on another site last year. Tongue in cheek the poster then said that over time as the O2 leaked out, and you refilled the tire with more air, over time you would have all N2 for free!! and that was his story and he was sticking too it Smile
Originally used in aircraft tires because it doesn't support combustion.
(04-22-2014, 07:31 AM)CBXBob_imp Wrote: Originally used in aircraft tires because it doesn't support combustion.
It's also used to fill the bags our snacks come in, as it helps retain the foods freshness and enhance shelf life.
(04-21-2014, 09:28 PM)Lord Popgun_imp Wrote: Ausieflyer,
That's always been my theory. You start with 78% nitrogen. Next time you top off the tire (to replace the oxygen that permeated through the rubber) you end up with 85% nitrogen and so on. After topping off the tire a few times, you should be pretty close to 100%.
  low oil pressure light Garuda78_imp 16 1,110 02-29-2024, 04:09 PM
Last Post: Garuda78_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 918 10-09-2023, 07:51 AM
  low oil pressure light kaput norton1974_imp 11 1,065 03-28-2023, 08:58 AM
  Interesting article on tire pressure the Ferret 9 840 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  Cold Weather & Tire Pressure 2017EX_imp 22 1,398 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Catalytic converter back pressure? ChipBeck_imp 13 967 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 967 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  Rear Brake Intermittent Loss of Pressure beardyweirdy@me.com_imp 9 655 11-04-2017, 12:26 AM
Last Post: Dengie Boy_imp
  Tire pressure Sonnyboy_imp 4 436 10-23-2017, 04:51 AM
Last Post: kennyw
  Tire pressure glynb_imp 12 899 09-29-2017, 03:00 AM
