tire pressure
What do you guys do in terms of tire pressure? my stock tires have a max of 42 PSI; the bike was delivered to me with 38 in the front and 45 in the back...is that bad? I have 38/38 now.
(04-18-2014, 02:59 AM)shdwghst457_imp Wrote: What do you guys do in terms of tire pressure? my stock tires have a max of 42 PSI; the bike was delivered to me with 38 in the front and 45 in the back...is that bad? I have 38/38 now.
I run 38 back and 34 front
36 Front, 42 Rear
"And the manual says"...... 36/42
And the sticker on the bike also says 36/42.....and thats where I keep mine.
of course that reading is taken before being ridden for the day, or at least not more than a couple miles in the last couple of hours.
I run 46f& 42r at 80 derees
Wow Wayne, that's 10 pounds above max rating on the tire. Hope thats a typo and you meant 36 f
Once again I'm ashamed to say, I have no idea as I've never checked. Feel ok though.
My tires are typically a couple pounds low over the course of a week or two. Bumpy roads may contribute. When the bike sat over the the winter the rear was 10 pounds low! Check your tires. The bike will ride better.
  low oil pressure light Garuda78_imp 16 1,090 02-29-2024, 04:09 PM
Last Post: Garuda78_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 886 10-09-2023, 07:51 AM
  low oil pressure light kaput norton1974_imp 11 1,016 03-28-2023, 08:58 AM
  Interesting article on tire pressure the Ferret 9 812 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  Cold Weather & Tire Pressure 2017EX_imp 22 1,316 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Catalytic converter back pressure? ChipBeck_imp 13 920 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 958 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  Rear Brake Intermittent Loss of Pressure beardyweirdy@me.com_imp 9 644 11-04-2017, 12:26 AM
Last Post: Dengie Boy_imp
  Tire pressure Sonnyboy_imp 4 427 10-23-2017, 04:51 AM
Last Post: kennyw
  Tire pressure glynb_imp 12 850 09-29-2017, 03:00 AM
