Speed Sensor
#41
(10-22-2013, 06:44 AM)Deanohh_imp Wrote: You can unplug the speed sensor if you don't mind getting an error code and check engine light, and no Speedo or odometer.
well when on a dyno, I unplugged the sensor wire right there by the air box and the bike went into some kind of safe mode.... Wouldn't go above about 6k in any gear. On my bike that does not defeat the speed limiter. Plugged back in and would get to about 9k in 3rd to get a map for upper rpms. Btw after mapping, max pwr 91.6, torque 69.7.
Staintune slip on, dome cut off snorkle with stock paper filter, pair hose blocked, power commander v.
(09-08-2013, 11:23 PM)CIP57_imp Wrote: Posted By CBXX
Ok, let me try this again. The speed sensor is the black
wire running along the rear swing arm on none abs models
from the rear brake caliper to the wiring harness inside the
right sidecover (one with CB1100 on it) by the air box lid.
You can unhook it/disable it but it is illegal to alter this
wire in Texas because it disconnects the speedo/odo which
would alter the actual miles of the vehicle when you sell it.
So now your top speed is faster but you cannot see it on dash.
Bike does not care what gear you are in, when speed sensor
sees 112 MPH it shuts off fuel/air. Done for Japan market.
This wire seems to be getting its read off of a round slotted disk mounted to the rear wheel. I masked and cover the holes of this disk and it had no effect on the speedo. I'm wondering if the removal of this indicator would not allow the limiter to read the 112 mph. You would probably have to re-balance your rear wheel. Any thoughts from the tech guys here??
About rebalancing your wheel, it's up by the axle, no effect whatsoever.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 99,186 07-26-2026, 01:51 AM
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,510 03-06-2026, 04:31 AM
  Oxygen lambda o2 sensor eliminator kit Davidjill_imp 4 522 11-09-2025, 06:23 AM
Last Post: AndyBeeMD
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 805 10-22-2025, 02:11 PM
  New speed meter replacement ACE_IRA_imp 3 478 02-13-2025, 06:25 AM
  How to remove O2 sensor CB1100AZ_imp 10 840 12-13-2024, 09:57 AM
Last Post: inditx_imp
  Bank angle sensor. Tezza_imp 8 714 08-06-2023, 05:57 PM
Last Post: Jurlie_imp
  fuel level sensor MBZM Rai_imp 11 832 04-11-2023, 11:38 PM
  Install a 6-speed trans on a 2013? amacbeth_imp 37 2,997 02-21-2023, 12:22 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,271 06-03-2022, 01:16 PM
