Speed Sensor
Posted By CBXX
Ok, let me try this again. The speed sensor is the black
wire running along the rear swing arm on none abs models
from the rear brake caliper to the wiring harness inside the
right sidecover (one with CB1100 on it) by the air box lid.
You can unhook it/disable it but it is illegal to alter this
wire in Texas because it disconnects the speedo/odo which
would alter the actual miles of the vehicle when you sell it.
So now your top speed is faster but you cannot see it on dash.
Bike does not care what gear you are in, when speed sensor
sees 112 MPH it shuts off fuel/air. Done for Japan market.
This wire seems to be getting its read off of a round slotted disk mounted to the rear wheel. I masked and cover the holes of this disk and it had no effect on the speedo. I'm wondering if the removal of this indicator would not allow the limiter to read the 112 mph. You would probably have to re-balance your rear wheel. Any thoughts from the tech guys here??
I doubt its a photo sensor of some sort, but I haven't checked. I would imagin its like, or is, a Hall effect sensor. In that care taping the hole most likely would not matter, and in your case it doesn't.
google hall effect sensor to see how they work
(09-09-2013, 12:18 AM)Lord Popgun_imp Wrote: I doubt its a photo sensor of some sort, but I haven't checked. I would imagin its like, or is, a Hall effect sensor. In that care taping the hole most likely would not matter, and in your case it doesn't.
Interesting read Pop, removing the plate would have the same effect as disconnecting the wire ?
It would also be interesting to hear the thought process involved in limiting this bike (and all others also?) to 112 mph in Japan. Did someone say that 110 mph is perfectly safe but once you get to 112... WHOA!!! now you guys are getting crazy?!?! I guess I am not understanding the logic that chose a mph limit rather than a rev limiter that serves the purpose of protecting the engine from over-revving while also keeping the mph down...
Are all models sold in the Japanese market limited to this same mph or is this somehow unique to the CB1100?
(09-09-2013, 04:54 AM)GUNFTR_imp Wrote: It would also be interesting to hear the thought process involved in limiting this bike (and all others also?) to 112 mph in Japan. Did someone say that 110 mph is perfectly safe but once you get to 112... WHOA!!! now you guys are getting crazy?!?! I guess I am not understanding the logic that chose a mph limit rather than a rev limiter that serves the purpose of protecting the engine from over-revving while also keeping the mph down...
IDK but you can be sure a lawyer or politician or both was the reason for it.
Its acutally 180 kph so its not an oddball number to them.
Don't really know much about this, but maybe worth looking into Huh
http://www.magnumtuning.com/en/detail/re...l-injected
Seems you need some kind of more advanced knowledge to get into the ECU. Again I don't know how difficult that would be/if that would actually defeat the limiter/if it voids any kind of warranty you might have.
(09-09-2013, 06:37 AM)Mackerel_imp Wrote: Don't really know much about this, but maybe worth looking into Huh
I wouldn't install that thing on my worst enemy's bike.
and out of curiousity, I did a bit of internet searching and this was near the top of the results.
http://www.japantimes.co.jp/life/2008/04...the-brake/
This explains exactly why it's in there to begin with.
Sorry about the bad spelling in my post Blush
I would think removing the plate would work. Or try using metal tape like HVAC guys use. I looked at mine and that sensor is pretty close to the disc so be careful.
I'm no expert on this, but doesn't the ECU need the speed input to run the fuel map correctly? Can someone comment on this?
  CB1100 Idle speed instability problem ericlo69_imp 1,434 99,197 07-26-2026, 01:51 AM
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,510 03-06-2026, 04:31 AM
  Oxygen lambda o2 sensor eliminator kit Davidjill_imp 4 522 11-09-2025, 06:23 AM
Last Post: AndyBeeMD
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 805 10-22-2025, 02:11 PM
  New speed meter replacement ACE_IRA_imp 3 478 02-13-2025, 06:25 AM
  How to remove O2 sensor CB1100AZ_imp 10 840 12-13-2024, 09:57 AM
Last Post: inditx_imp
  Bank angle sensor. Tezza_imp 8 714 08-06-2023, 05:57 PM
Last Post: Jurlie_imp
  fuel level sensor MBZM Rai_imp 11 832 04-11-2023, 11:38 PM
  Install a 6-speed trans on a 2013? amacbeth_imp 37 2,998 02-21-2023, 12:22 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,272 06-03-2022, 01:16 PM
