Charcoal canister removal
(09-01-2014, 02:12 AM)Dave_imp Wrote:
(08-31-2014, 04:20 PM)Flynrider_imp Wrote: Siggy, that roughness at low throttle settings is probably not related to the cannister. Quite a few folks on the forum have noticed it, including myself. Mine has done it since new. I suspect it's a lean condition, most likely related to emission control. On my bike it's roughest about 1800-2K rpm then disappears above that.
I created a post about the fuel injection problems I am experiencing with my 2014 CB1100 here a few months back. I have not kept it up-to-date, but in summary:
1. The throttle bodies on my bike are not synchronized - I posted a picture of the electronic vacuum gauge reading on this forum.
2. My bike has been returned to the dealer four times - the Honda mechanics claim it runs "fine" - it does not.
3. An electronic diagnostics test has been performed by Honda twice - both times the results were satisfactory.
4. Below 3,000 RPM and at very light loads my bike runs poorly - you can hear it mis-firing.
5. From stoplight to stoplight (one block apart) my bike is annoying to ride. My bike has somehow, mysteriously been running better as the miles have increased (3,000 miles now) - but it still does not run acceptably.
6.On the back roads, in corners, where you let the RPM drop below 3,000 is where it is most noticeable - and annoying. The engine stumbles (slightly) as the throttle is applied below 3,000 RPM, then suddenly comes to life above 3,000 RPM (actually closer to 3,200 RPM).
7. After four visits to the dealer, multiple phone calls to the factory and a threat to invoke the California Lemmon Law, Honda is arranging to have a "factory representative" present when Honda can perform their own vacuum test.
8. I love my bike, and if Honda cannot / does not repair it to my satisfaction then I will repair it myself - contrary to common belief the throttle bodies can be adjusted. I am convinced that synchronizing the throttle bodies on my bike will improve its performance (I have years of experience synchronizing carburetors on 4-cylinder bikes).
Or- the built in cam timing cylinder differences....
No update?
  Valve Adjustment and Camshaft Removal dave 5 584 03-21-2026, 04:49 PM
  Left side cover removal jeffmazz_imp 24 1,965 07-09-2025, 03:37 PM
Last Post: bflint
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 5,470 07-25-2022, 06:54 AM
  Easy bar end weight removal brian10x_imp 6 605 06-06-2022, 01:04 AM
Last Post: 1973cb750
  Air box removal ACE_IRA_imp 23 1,516 09-25-2020, 05:56 AM
Last Post: ACE_IRA_imp
  Fuel Tank Removal Gabby_imp 11 873 06-19-2020, 10:54 AM
  Canister removal Feelergaugephil_imp 2 292 10-11-2019, 10:59 PM
  Handy Cheat Sheet for Maintenance and Wheel removal on my 2017 17-CB-002 12 812 04-17-2019, 12:40 AM
Last Post: ArbitraryThawt_imp
  tire removal jdgrego1_imp 27 1,627 11-15-2018, 07:18 AM
Last Post: jdgrego1_imp
  Heated grips removal Chris potato_imp 7 425 07-26-2018, 11:27 PM
Last Post: itstuantran_imp
