Left side cover removal
(03-20-2019, 10:29 AM)younggun.45_imp Wrote: Thanks for posting this thread! I am going to find out if the '13 & '14 crankcase covers compatible when I get the motivation. This helped for sure.
Younggun, check this out: http://cb1100forum.com/forum/showthread....#pid234370
Younggun, yeah, we're in the wrong thread, but check this out: http://cb1100forum.com/forum/showthread....#pid234370
Sorry. I'm not sure what happened. Meant to put it in the "Left Side Cover Removal" thread. Still getting use to the forum format.
No problem Younggun. Its pretty lax here. Cormanus and Ferret rarely have to fly in to “take care of business” if you get my drift. Smile
It's now even weirder because I've moved the posts and edited them slightly. But, at least they're in the right place. Smile
(10-27-2017, 08:20 AM)jeffmazz_imp Wrote: Can someone help me with the left side cover removal? I have the gasket released but the cover comes off about 1/4" and stops. It feels like there is something in there not allowing it to fully release. Should I keep pulling or is there something I'm missing? The electrical wire that goes in the top isn't the issue. Also does anyone have the torque values for the cover bolts?
Any advice will be greatly appreciated.
Jeff
In one of these threads on the old forum someone mentioned there are 3 tabs on the alternator cover to help pry it away from engine case .... I can't find the darn thread now but THANK YOU to whomever it was.   I took a pic of the tabs (blue tape stuck behind each to better see the little guys).
Attached Files Thumbnail(s)
  Valve Adjustment and Camshaft Removal dave 5 608 03-21-2026, 04:49 PM
  Left Side Crankcase Gasket Part number. jbird06_imp 1 314 03-26-2024, 08:56 AM
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 5,713 07-25-2022, 06:54 AM
  Easy bar end weight removal brian10x_imp 6 614 06-06-2022, 01:04 AM
Last Post: 1973cb750
  Question on replacing engine side cover Ollie 11 766 01-10-2022, 11:21 AM
Last Post: Ollie
  Tank decal and the junk left behind Gordo_imp 13 1,020 09-06-2021, 02:29 PM
  2014 Right Side Cover--Red eddi0_imp 12 1,108 06-07-2021, 09:16 PM
Last Post: eddi0_imp
  left crank cover calipo223_imp 3 371 05-05-2021, 06:29 AM
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,539 12-04-2020, 12:29 PM
Last Post: 17-CB-002
  Air box removal ACE_IRA_imp 23 1,566 09-25-2020, 05:56 AM
Last Post: ACE_IRA_imp
