left crank cover
Just a quick question gents. I'm changing out my left crank cover. I thought it was hollow.. but when I saw some pictures from here I noticed the gears . My question is is there a problem with transferring the gears to the new crank cover? On a 1 to 10. where would you rate the job? thanks in advance Calipo
This is an easy job, maybe a 4 or 5, but there are 2 areas to be especially careful. The starter gear cover and gear come of easily enough, as does the main cover.
The areas to pay particular attention are the routing of the alternator cover wires. If you don't have a manual, take pictures of the inside of the cover. The other area of concern is using the correct gasket sealant, not too much, but just enough so it doesn't squish out - remember, what squishes out also squishes inward.
Make sure the gasket surfaces are clean, and that you have sealant around the molded rubber grommet that the wires come through.
Thank you Peking duck. I appreciate your help.
(05-05-2021, 05:59 AM)calipo223_imp Wrote: Thank you Peking duck. I appreciate your help.
let us know how it went, or if you have any questions. And use the Honda or Yamaha gasket sealant, not just silicone. Good luck.
  Left side cover removal jeffmazz_imp 24 2,248 07-09-2025, 03:37 PM
Last Post: bflint
  Left Side Crankcase Gasket Part number. jbird06_imp 1 337 03-26-2024, 08:56 AM
  Should I adjust my crank balancer? DutchRutter 16 1,371 05-29-2022, 07:39 AM
Last Post: DutchRutter
  Tank decal and the junk left behind Gordo_imp 13 1,090 09-06-2021, 02:29 PM
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,761 12-04-2020, 12:29 PM
Last Post: 17-CB-002
  Weak Crank Case Bolts? bertypower_imp 19 1,625 09-12-2020, 10:22 AM
Last Post: bertypower_imp
  2013 cb1100 Left Directional Light wont cancel. M3-SRT8_imp 15 1,217 08-01-2020, 07:16 PM
Last Post: max
  Bike crank but wouldn't start. zirconxi_imp 67 4,315 04-25-2020, 01:37 AM
Last Post: White Dog_imp
  Replacing Left Side Engine Cover will866_imp 4 381 03-29-2018, 10:36 AM
Last Post: jeffmazz_imp
  left control wiring caddy425_imp 2 329 03-26-2018, 12:42 PM
Last Post: caddy425_imp
