Question on replacing engine side cover
I will be replacing a left and right side engine cover and it appears that during assembly a gasket caulk was used rather than paper gaskets. Any suggestion on the best stuff to use, and also how to separate the covers away after the bolts are removed? Any tips are appreciated.
No point in using anything other than the correct adhesive.
A small soft faced dead blow hammer works great for tapping the covers loose.
I agree do you happen to know what the correct adhesive is? Is it a type I can pick up at NAPA, or something Honda specific? Good suggestion to use a mallet in fact I used one once before when taking a side cover off but it utilized a gasket and the cover separated off fairly easily. I never took one off that had been put together with adhesive.
Stator side is held by the magnetic action of the stator, use a stiff plastic putty knife to get a clearance of about 1/4 inch then it will break free. Book calls for Honda bond sealant.
Three Bond 1207B Gasket Maker... https://www.amazon.com/dp/B008BYPRRI?ref...b_ap_share
Great thank you, I stop by for Honda Bond sealant and if they don't have that I'll order 1207B from your Amazon link.
They had two types of Hondabond liquid gasket. I decided on Hondabond 4 for sealing the lower side cases figuring the HT was more for High Temperature such as the head? If this seems wrong let me know and I'll exchange it.
I've been using Permatex for longer than 2 decades.......
Ultra Black Gasket Maker 598BR, 80-mL...and many more by the same company.
Use a proper one.
The last time I had to use any liquid gasket was back in 1986, and that was on a car! Before that, 1984 on a Yamaha.
Japanese bikes have been ultra reliable in regards to seal leaks.
(01-10-2022, 08:38 AM)peterbaron_imp Wrote: I've been using Permatex for longer than 2 decades.......
Use a proper one.
Well that's the intent of this topic. Of the ones that have been mentioned here, Hondabond (there are 2), Three Bond 1207B, and Permatex 598BR, would any not be suitable? Is one of them "best"?
  Left side cover removal jeffmazz_imp 24 2,237 07-09-2025, 03:37 PM
Last Post: bflint
  Engine Cover Paint deltamark 9 849 09-05-2023, 06:22 AM
  Milage when replacing chain and sprockets Frulk_imp 8 691 02-11-2023, 03:29 PM
Last Post: Frulk_imp
  Replacing Wheels - Manual Instructions Ludicrous jasonsargonautalis_imp 12 1,289 12-11-2021, 08:52 AM
Last Post: jimgl3_imp
  Replace or leave on? Nicked an engine cover. Hovmod_imp 17 1,261 08-02-2021, 04:03 AM
Last Post: le_penseur_imp
  2014 Right Side Cover--Red eddi0_imp 12 1,203 06-07-2021, 09:16 PM
Last Post: eddi0_imp
  Battery Cover Question syrio_imp 26 1,850 12-18-2020, 09:33 PM
Last Post: tod.branko_imp
  Engine Guard Install Question? linuxology_imp 27 1,928 07-25-2020, 08:52 PM
  Location of Engine Number on Engine? cb1100_dude_imp 2 335 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  Replacing turn signal bulb on a 14. the Ferret 7 525 04-24-2019, 01:33 AM
Last Post: Rocky_imp
