Shifting issues
My six speed occasionally doesn't like to downshift unless the bike is moving.
If I forget to shift all the way down to first at a stop, especially in a panic braking situation, it often will not allow me to shift into first unless I rock the bike or roll it forward a bit.
I've had to leave a few intersections slipping the clutch in either second or third gear.
Mine had a break-in period where shifting was rough. My switch to Amsoil and the subsequent break-in greatly improved the shifting. Your results may vary.
(03-27-2015, 04:59 AM)Gumby 1100_imp Wrote: My six speed occasionally doesn't like to downshift unless the bike is moving.
Gumby if you come to that situation again, just let out the clutch until you can feel it engage a bit, then quickly pull the clutch in, and you can continue down shifting. No need to slip the clutch.
Thanks! I'll give that a try as soon as the weather permits me to put the bike back on the road after it's winter hibernation. Wink
(03-27-2015, 04:51 AM)JustPassinThru_imp Wrote: I have noticed this on my CB here...and with other Japanese bikes in years past.
In my case, it's not shifting UP but DOWN. Started doing this at about 400 miles. If I downshift at higher speeds, it seems to be fine; but if I idle up to a light and start running the gears down at about 20...I have issues.
Letting the clutch out and putting some torque on the input shaft gets the gearbox to pop all the way into the gear. Hope it's not trashed; or if it is, that it hurries up and fails before the warranty runs out.
It's not trashed. That's normal behavior for this bike. It seems particularly sensitive to downshifting from the higher gears when slowing to a stop. Whenever I find myself in that situation and I'm not getting a downshift, I bump the clutch to the friction point and that does the trick.
My CB750 is similar, but not quite as sensitive. It'll keep downshifting until the bike slows to around 5 mph or less. The CB11 seems hesitant under 10 mph.
I put Kury grips on my new 1100 and quickly had down shifting problems. A change to a lower number on the clutch handle dial solved the problem.
Been shifting motorcycles since 1980.
When downshifting through gears you have to clear meaning don't come to a stop in 2nd or third gear. Let each gear have a positive downshift until in second than go to neutral before you stop. No tranny likes to shift from 5 (or 6th) to 4th or 3rd with the same clutch pull. The tranny's today are much better than the past but still require you clear synchros.
Think of riding a bicycle, when you shift you have to be pedaling in order to get a positive shift, same goes for a motorcycle you have to be moving. Trucks often have to double clutch to synch the tranny.
No synchros in bikes trannys, and no harm in shifting down through the gears at idle or low engine speeds, but chances of gear dogs engaging are not so good in the lower gears - let the clutch out a little, shaft speeds will change, and the gear dogs can engage. Never stomp on the gear lever.
I agree along the line of what rocket said but for a different reason. Since all 3 of your described missed shifts are on upshifts, its very likely your footwear. Softer shoes or boots or sneakers are not good. You feel the soft material compress, and you think your foot, and hence, your shifter is moving more than it is, and you think you moved the shifter enough, and ease up prematurely. Make quick and firm movements. Don't baby it.
  Shifting issue Cormanus 31 2,444 05-15-2024, 12:59 AM
  Smooth shifting DougsZ28_imp 16 1,434 07-09-2021, 07:32 AM
  No clutch shifting Mixagon_imp 26 1,823 06-21-2021, 10:35 AM
Last Post: cj599_imp
  Trouble shifting CB1100AZ_imp 27 2,003 03-01-2021, 08:25 AM
  Headlight High Beam Issues omarj_imp 5 534 01-21-2021, 11:07 AM
  2013 Starting Issues BackroadsRider_imp 6 597 03-10-2019, 10:45 AM
Last Post: flynrider
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,292 02-11-2019, 01:55 PM
  tps evaluating for ii issues max 155 11,142 02-20-2018, 10:00 AM
Last Post: SportsterDoc
  I fixed my clunky-shifting transmission dave 11 1,338 11-20-2017, 05:22 AM
  Idle issues Macenthor_imp 4 411 01-03-2017, 11:56 PM
Last Post: johnf514_imp
