Smooth shifting
Is there anyway I can get my gearbox to shift smoother? I have read somewhere that if the gears were cut different that it would smooth out the shifting instead of clunking! Anyone hear of this?
I've found that when I exaggerate the throttle blip (closing it futher than I do on some other bikes), I get a buttery smooth, silent shift every time.
I'm using the recommended Honda GN-4 10W-30 and have diligently replaced the clutch (and brake) fluids every two years. I'm at 36,000mi...
If you’re not doing so already, try lightly preloading the shift lever before disengaging the clutch. Then, when you’re ready to shift, disengage the clutch while continuing to preload the shifter and you might find the gears changing more smoothly.
(07-06-2021, 12:16 PM)LongRanger_imp Wrote: If you’re not doing so already, try lightly preloading the shift lever before disengaging the clutch. Then, when you’re ready to shift, disengage the clutch while continuing to preload the shifter and you might find the gears changing more smoothly.
(+1) for the LongRanger.
(+1) for the LongRanger. I'll give it a try, thanks!
Yeah, I would say it has by far the biggest impact on improved smoothness.
A secondary change for myself was the oil:
Motul 5100 or Rotella T6 10W40.
Hard to describe, but smoother than a blunt hot knife sliding down a brick of fresh, farm dairy butter.
A loose or worn chain (with tight spots) will cause clunky shifting, even slightly loose. Keep your chain well lubricated.
(07-07-2021, 01:26 AM)Dave_imp Wrote: A loose or worn chain (with tight spots) will cause clunky shifting, even slightly loose. Keep your chain well lubricated.
The Tutoro auto chain lubricator will make that task essentially zero effort.
don't use the clutch works also. forces you to rev match and take the strain off the gears before you shift.
Hard to describe, but smoother than a blunt hot knife sliding down a brick of fresh, farm dairy butter. Thats the cure, I went to a 5-20 synthetic and it cured the problem! Thanks
  Shifting issue Cormanus 31 2,458 05-15-2024, 12:59 AM
  No clutch shifting Mixagon_imp 26 1,841 06-21-2021, 10:35 AM
Last Post: cj599_imp
  Trouble shifting CB1100AZ_imp 27 2,035 03-01-2021, 08:25 AM
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,298 02-11-2019, 01:55 PM
  I fixed my clunky-shifting transmission dave 11 1,338 11-20-2017, 05:22 AM
Last Post: SportsterDoc
  clanking when shifting PilotPaul_imp 53 3,818 11-09-2016, 05:29 AM
Last Post: Ulvetanna_imp
  Bike stalls shifting into 1st gwallis_imp 19 1,294 11-07-2016, 04:10 AM
Last Post: kennyw
  Trouble With Shifting From 1st to 2nd & 2nd to 1st goldeneye_imp 14 942 09-26-2015, 05:31 AM
Last Post: wiredgeorge_imp
  Very clunky shifting kDiqq_imp 39 2,770 04-26-2015, 10:42 AM
Last Post: Zappertomm_imp
  Shifting issues holy666diver_imp 18 1,202 03-28-2015, 11:09 AM
Last Post: ClassicVW_imp
