No clutch shifting
Just been reading the clutch lever post and it got me wondering about an old subject which may have been discussed on here or not so here goes..
How many of you change gear without using the clutch ?
I've been doing it for years on the upshifts which is so easy and smooth and sometimes do it on the downshifts if conditions are right but not very often.
I ALWAYS use the clutch !
^^+1^^
Why would you not use the clutch?
another clutch lever user here, on every shift up or down
(+1) Use clutch, however, there have been numerous times I geared down without the clutch and without incident.
(06-17-2021, 09:25 PM)Dave_imp Wrote: Why would you not use the clutch?
Well yes that's what it is there for Big Grin
Maybe its from days gone in the race world UK when riders could save time by shifting without the clutch so all the street guys learned the skill to be cool.
To be honest its a skill that has saved me many times in the past when a clutch cable breaks and I've rode home without a clutch otherwise I would have been stranded. I've even drove 120 miles home in a 72 Ford Cortina with a broken clutch cable. More challenging than a bike but its possible, of course if your timing is bad and you have to stop you have to start moving again in first gear with the starter motor.
Re bikes though its so easy changing up that it sometimes feels pointless using the clutch. Been doing this for over fifty years and never had any gearbox problems.
I use the clutch to start and stop and that's it. All gear shifting is clutchless, unless I'm out of sorts and need the clutch...
I'm not so sure that you can shift quicker without the clutch than with. You have to back off the throttle, and move the shift lever to make a clutch-less shift don't you?
From an article I just read on shifting: https://www.revzilla.com/common-tread/ho...motorcycle
"Clutchless shifting
You know how we said the clutch acts to disengage the crankshaft from the transmission to unload the gears and allow them to shift positions? Well that same unloading effect can be achieved by quickly and briefly rolling the gas off and then back on again. In that instant right after you air the throttle, the transmission is unloaded. If you time your upshift to coincide with that momentary unloading of the transmission, the bike can be shifted up up into the next gear. No clutch required. "
In that same time it takes to roll the throttle off and back on you could fan the clutch blade and make the shift without even rolling off the throttle if desired.
Now the new speed shifters you shift without backing off the throttle so they are quicker than an old time clutch-less shift I would think, with less risk of damage to the trans
That said, I just don't see the point of either method for riding on the street. Maybe on a race track where tenths of a second matter.
Oh and the DCT trans is even quicker at shifting yet, all controlled by computer, quickly and seamlessly with no possible damage to any transmission parts
... yeah, even if you manually shift a Honda dual clutch transmission, I don't think Honda software will allow any excessive or "bad timing" of the shift convert to mechanical trauma. This is quite cool.
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,319 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 1,002 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,084 11-22-2024, 07:49 AM
  Shifting issue Cormanus 31 2,391 05-15-2024, 12:59 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 250 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,584 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 659 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 519 02-21-2023, 10:48 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 399 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  brake & clutch adjusters The Gecko_imp 10 877 11-25-2022, 08:47 AM
