2013 Starting Issues
My 2013 CB1100 on occasion fails to start. Ignition switch on as well as neutral light. Kick stand up. No response of any kind when I push starter button? After turning key on and off and flipping kick stand up and down repeatedly it decides to start...so far. Any ideas as to where the problem might be? Low mileage garage kept bike.
I would check the battery cable connection, clean them and tighten.
I'd start with the safety switch in the kick stand. Could also be a problem in the emergency stop switch.
I've also a vague memory of a connection around the clutch lever that can cause problems.
(03-09-2019, 10:07 AM)Cormanus_imp Wrote: I'd start with the safety switch in the kick stand. Could also be a problem in the emergency stop switch.
^^^This....so much this.
Mr BRR, here is a drawing i made with the help of one of "the team's" diagrams and recognizing all their input.
From what you describe it points to the start switch itself OR the wiring to it including the diode block and the start motor relay, the start motor relay is supplied from the start button which gets it's supply from the engine stop switch.
A; If the instruments sweep that indicates the key switch is working,
B; if the fuel pump initiates that indicates the "engine stop switch" is working and
C; if the neutral light is on that means the bike is ready to be started.
The clutch switch and the sidestand switch only stop the bike from being driven with the stand out and the engine will stop, this seems not to be the problem in your case and is a separate electrical circuit.
The clutch and sidestand are in parallel and either one can ground a pin ( b22 ) to the ecm and if both are open the ecm recognizes a potentially dangerous situation and then kills ignition if the bike is not in neutral ( pin b33 ) Not shown on this drawing which i made to be read a bit better than the complex wiring diagram.
[Image: c48f5876762ba7a26d3819361a9b5670.jpg]
Hope you can understand european symbols with their explanation and the current flows from the battery at the top to the bottom through all the parts.
The bank angle sensor stops the electrical supply to the control circuit and stops the engine if it has fallen over to stop the wheel from spinning, it is not the cause of your particular problem but i have drawn it to better understand the working of the engine stop relay.
The function of the diode block is to combine the neutral light indicator separate from the starting circuit, so although they are connected together they function separately without influencing each other, the diode block is located beside the fuses and relays under the seat and normally does not need attention, it is removable by pulling it up like a relay and maybe reversible if the pins allow it.
Hope this helps to locate the intermittent issue.
(03-09-2019, 12:03 PM)max_imp Wrote: Mr BRR, here is a drawing i made with the help of one of "the team's" diagrams and recognizing all their input.
Thanks for such a thorough explanation on how this all works. I appreciate you taking the time.
Thanks for suggestions. Good places to start.
I had an issue with the kill switch a few years back. The obvious symptom was that the gauges would sweep, but the fuel pump would not activate when the key was turned on. Also, the "check engine" indicator does not illuminate momentarily as it normally does.
It turned out to be some minor corrosion on the kill switch contacts. I recall that a few other members have had this issue.
I wouldn't worry about the side stand switch. The bike should start in neutral regardless of the position of the side stand.
  starting issue jigs_imp 12 836 06-06-2021, 01:51 PM
Last Post: max
  Headlight High Beam Issues omarj_imp 5 518 01-21-2021, 11:07 AM
  tps evaluating for ii issues max 155 10,694 02-20-2018, 10:00 AM
Last Post: SportsterDoc
  Idle issues Macenthor_imp 4 400 01-03-2017, 11:56 PM
Last Post: johnf514_imp
  Guhl Motors and ECU Re-Map for DLX / EX with Idle Issues beardyweirdy@me.com_imp 11 824 12-22-2016, 12:40 PM
Last Post: Retsel_imp
  New Honda ECU Software, Idle Issues and a Re-Flashed ECU beardyweirdy@me.com_imp 15 1,205 10-27-2016, 03:11 AM
Last Post: StefanS_imp
  Bike is starting to Irritate me re oil filter backing out jazzmans_imp 38 2,795 02-27-2016, 10:39 PM
Last Post: Razor
  Cranking w/o starting. kmoney_imp 3 317 04-19-2015, 04:02 AM
Last Post: kmoney_imp
  Shifting issues holy666diver_imp 18 1,153 03-28-2015, 11:09 AM
Last Post: ClassicVW_imp
  battery /charging system issues dlhmatt_imp 25 1,715 04-15-2014, 11:59 PM
Last Post: dlhmatt_imp
