Headlight High Beam Issues
Hi All,
I recently upgraded my headlight on a 2017 CB1100EX to:
https://www.samurider.com/?p=28865
While it initially works great, and still does it sometimes randomly turns on the high beam here and there, and stays on. As I'm not mechanically inclined I'm not sure what's going on, but could it be loose cable that maybe I just need to electrical tape, any thoughts/ideas on how to fix?
Additionally when the high beam turns on the dash signal does not go on. Not sure if that helps in the diagnostic.
Any help/thoughts would greatly be appreciated!
Wow, that is weird. I had some issues when I went from a normal bulb to an LED on my '13, and it turned out to be a defective bulb. But the '17 comes with an LED as standard, doesn't it?
Strange, from the pic, it looks like plug n play kit...no splicing ??
PB, my thoughts exactly. I wonder if that little module is failing.
(01-21-2021, 10:48 AM)Lord Popgun_imp Wrote: PB, my thoughts exactly. I wonder if that little module is failing.
Possible or it could be as simple as poor contact somewhere.
Would like to see its instruction, doubt there is any detailed diagram for p n p..???
Not a rocket....,Smile
Could very well be the controller. It is the weakest link.
Also check those feeble connectors.
RE dash indicator: Could be a number of things, beginning with the controller and/or wiring.
  Headlight shell Lord Popgun 11 1,600 10-08-2025, 01:17 PM
  2017 MY CB headlight upgrade. 17-CB-002 16 2,370 09-06-2025, 05:00 PM
  'Factory' high performance spark plugs PowerDubs_imp 17 1,515 10-23-2024, 02:50 PM
Last Post: rtmoto1
  High engine revs on start up CBX1000_imp 21 1,926 06-06-2024, 02:40 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,891 09-14-2023, 10:08 PM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 5,150 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  High mileage and oil consumption Jurlie_imp 24 2,323 04-07-2023, 06:05 AM
  auxiliary 12v in headlight shell Maturecheese_imp 6 671 03-25-2023, 07:14 AM
  Delay when using headlight switch? Jgarciajr40_imp 15 1,177 12-05-2022, 07:11 AM
Last Post: max
  High idle mattmcuomo@yahoo.com 7 714 10-29-2022, 11:09 AM
