11-19-2015, 08:26 AM
gas tank removal
11-19-2015, 10:13 AM
Yes, I did.
11-20-2015, 05:04 AM
11-20-2015, 09:27 AM
So long as you don't have to disconnect the fuel line, then don't worry about it. If you need to disconnect it, then I would.
11-28-2015, 12:11 PM
the trick on getting the fuel line off is to pull away the soft black rubber insert, squeeze the green clamp ends inward while gently pulling the line off. There are 2 raised areas on the line you must clear.
« Next Oldest | Next Newest »
| Valve Adjustment and Camshaft Removal | dave | 5 | 603 |
03-21-2026, 04:49 PM Last Post: Cormanus |
| Left side cover removal | jeffmazz_imp | 24 | 1,987 |
07-09-2025, 03:37 PM Last Post: bflint |
| HELP GAUGE REMOVAL /CUSTOM TACH | 911jimmy_imp | 96 | 5,600 |
07-25-2022, 06:54 AM Last Post: GoldOxide_imp |
| Easy bar end weight removal | brian10x_imp | 6 | 607 |
06-06-2022, 01:04 AM Last Post: 1973cb750 |
| Air box removal | ACE_IRA_imp | 23 | 1,532 |
09-25-2020, 05:56 AM Last Post: ACE_IRA_imp |
| Fuel Tank Removal | Gabby_imp | 11 | 882 |
06-19-2020, 10:54 AM Last Post: Cormanus |
| Canister removal | Feelergaugephil_imp | 2 | 302 |
10-11-2019, 10:59 PM Last Post: Lord Popgun |
| Handy Cheat Sheet for Maintenance and Wheel removal on my 2017 | 17-CB-002 | 12 | 828 |
04-17-2019, 12:40 AM Last Post: ArbitraryThawt_imp |
| tire removal | jdgrego1_imp | 27 | 1,751 |
11-15-2018, 07:18 AM Last Post: jdgrego1_imp |
| Heated grips removal | Chris potato_imp | 7 | 428 |
07-26-2018, 11:27 PM Last Post: itstuantran_imp |
