Torque wrench ?
I have the Harbor Freight one. It is mechanical and works fine. It's the only one I have ever owned, so I don't really have anything to compare it to, but for my purposes, it works fine and was fairly cheap.
I think I'll go with harbor freight one. thanks for all the input guys.
BTW... those top rear shock bolts break off entirely too easy. I got lucky and a few taps with a screw driver and they twisted themselves out.
I have 3 torque wrenches. The lowest is in inch pounds, one from 10-80 lbs and a biggie for in excess of 100 lbs. They all overlap to some degree but I am told a torque wrench at either end of its scale is useless, as in inaccurate readings.
  Torque value question Jonnyteabag_imp 9 682 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 663 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 438 04-03-2021, 01:35 AM
  Engine mount bolt torque value TCinNC_imp 43 2,961 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Shock bolt torque HBFL_imp 9 767 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,171 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,279 10-25-2018, 02:25 AM
Last Post: HBFL_imp
  Torque spec for motor mount? PAULIBIKER_imp 3 404 09-10-2018, 07:35 AM
  Torque wrench woes postoak_imp 17 1,105 08-10-2018, 08:44 PM
  3 in 1 Filter Wrench, 17mm Magnetic Drain Bolt, OEM Oil Filter, Crush Washers? LordWasr_imp 25 1,695 04-23-2018, 08:54 AM
Last Post: LordWasr_imp
