Torque wrench ?
Anyone have a link or recommendation. All the local shops don't seem to have one that will go low enough for some of the bolts on the CB1100. Rear upper shock is at 6.6 foot lbs.
inch lbs have a conversion ?
Possibly silly question. Just don't have much experience with them. Any help would be greatly appreciated.
Thanks,
JF
12 inch pounds = 1 foot pound.
24 inch pounds = 2 foot pounds and so on...
Your 6.6 foot pounds = 79 inch pounds (6.6 x 12 = 79.2)
you won't find one torque wrench that will do the upper shock bolts and the rear axle nut. Buy an inch pound torque wrench and a 0-100 foot pound torque wrench.. Sears, Harbor Freight, probably Loews, Home Depo, Ace etc
Haha nice, simple math. Thanks guys. I figured that much but needed to hear it from the board. Thanks!!
These are handy tools... use them with any ratchet, plus they can also be used to check the calibration of your old mechanical torque wrenches:
https://www.amazon.com/gp/product/B004VY...PDKIKX0DER
https://www.amazon.com/ACDelco-ARM602-4-...S7Z40K606E
(05-21-2017, 11:01 AM)BestStandard_imp Wrote: These are handy tools... use them with any ratchet, plus they can also be used to check the calibration of your old mechanical torque wrenches:
Man, what will they think of next? What an ingenious idea!
That's an amazing idea! Why buy a separate mechanical torque wrench if you can get one of these?
'Cause an electronic beep will never be as satisfying as the solid 'clunk' of a torque wrench?
Beep? Click?
My 1/4" beam-type torque wrench is totally silent, needs no calibration or batteries, is quicker, cheaper, measures break-away torque, and you can watch as torque increases.
I have click-types too, but don't need a digital one. I have enough stuff that gets used lightly, but still kill the batteries when I need it. I am constantly replacing batteries in meters, calipers, smoke detectors, scales, security alarms, tire pressure gauges, etc.
I'm old fashioned I guess, as I use both inch pound and foot pound torque wrench's that click/break.
No assembly or batteries required Big Grin
  Torque value question Jonnyteabag_imp 9 683 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 670 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 438 04-03-2021, 01:35 AM
  Engine mount bolt torque value TCinNC_imp 43 2,981 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Shock bolt torque HBFL_imp 9 769 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,189 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,279 10-25-2018, 02:25 AM
Last Post: HBFL_imp
  Torque spec for motor mount? PAULIBIKER_imp 3 404 09-10-2018, 07:35 AM
  Torque wrench woes postoak_imp 17 1,125 08-10-2018, 08:44 PM
  3 in 1 Filter Wrench, 17mm Magnetic Drain Bolt, OEM Oil Filter, Crush Washers? LordWasr_imp 25 1,700 04-23-2018, 08:54 AM
Last Post: LordWasr_imp
