Tire pressure
My BT54 front tire was worn down to the wear bars at 7200 miles. There was plenty of tread left on the rear tire. Unfortunately I could find replacement BT54's so I went with BT45 replacements for both front and rear.
I check tire pressures before every ride and run 36 psi for the front and 42 for the rear.
I've got 6700 miles on the BT45's now and the front is starting to cup a bit so I'll probably raise the pressure to 38 to see if it smooths out. The rear tire is flattened on the crown so I guess I've been riding on strait roads too much. Tread depth is fine on both tires.
The BT45's have 4.2/32 inch tread depth on the front and the rear has 5.7/32 inch on the rear according to [url=https://www.totalmotorcycle.com/photos/tire-tyre-guide/Bridgestone-BT45]this site.
(09-28-2017, 09:42 PM)curlyjoe_imp Wrote: My BT54 front tire was worn down to the wear bars at 7200 miles. There was plenty of tread left on the rear tire. Unfortunately I could find replacement BT54's so I went with BT45 replacements for both front and rear.
Hey there Curly, a lot of numbers on that site and easy to go crossed eyed looking at the table of BT45 data ... the tread depth is:
Front - 6/32", and
Rear - 9/32"
Front - 6/32", and
Rear - 9/32"
Front - 6/32", and
Rear - 9/32"
Thanks for the correction Aussieflyer. Read the wrong column! It’s tough getting old.
  low oil pressure light Garuda78_imp 16 1,090 02-29-2024, 04:09 PM
Last Post: Garuda78_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 886 10-09-2023, 07:51 AM
  low oil pressure light kaput norton1974_imp 11 1,013 03-28-2023, 08:58 AM
  Interesting article on tire pressure the Ferret 9 810 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  Cold Weather & Tire Pressure 2017EX_imp 22 1,316 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Catalytic converter back pressure? ChipBeck_imp 13 919 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 958 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  Rear Brake Intermittent Loss of Pressure beardyweirdy@me.com_imp 9 644 11-04-2017, 12:26 AM
Last Post: Dengie Boy_imp
  Tire pressure Sonnyboy_imp 4 427 10-23-2017, 04:51 AM
Last Post: kennyw
  Oil filter failure.... Complete loss of oil pressure x(why)z_imp 49 2,882 09-14-2017, 10:12 PM
Last Post: paulw_imp
