 Turn lights would not work
(01-01-2020, 01:41 PM)The ferret_imp Wrote: Glad it worked out.
Just to be clear, you sprayed electrical contact cleaner in the slot for your turn signal switch and it freed it up and became easy to use? You did not take the switch apart and clean the contacts?
Sorry for not clarifying it clearly, yes just used its blue pipe attached to spray can, used 2-3 puffs in the opening slot without taking the unit appart, the pipe was tiny enough to enter in to the unit, total of may be 5 sprays for bike ,I can probably use the can for the rest of the life of all bikes in my riding group.
Ride safe/Ride long
Good deal, glad it worked. Mine felt a little stiff today (compared to the FJR's switch) so I may pick some of that up and give it a couple of shots.
(01-01-2020, 02:01 PM)The ferret_imp Wrote: Good deal, glad it worked. Mine felt a little stiff today (compared to the FJR's switch) so I may pick some of that up and give it a couple of shots.
Good luck.
Good work, Ennsync. Thanks for letting us know.
It is always nice when people let us know that something worked after asking a question on the Forum. Many times we do not hear anything after us giving suggestions for taking care of a problem.
Bring back the art of common courtesy to the masses.
  Bead method of balancing tires, does it work? MagnaRider 3 437 01-06-2025, 03:03 AM
Last Post: MagnaRider
  Cams, Compression, Head Work? boynton6spd_imp 12 992 08-08-2021, 02:27 AM
Last Post: old blue_imp
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,589 10-15-2020, 02:13 PM
Last Post: max
  Turn Signals/Hazard Lights - Not Blinking/Not Turning on mnm2008_imp 20 1,377 06-24-2018, 02:39 PM
  Check engine lights up. Not blinking itstuantran_imp 30 2,331 05-04-2018, 11:04 AM
Last Post: SportsterDoc
  Rear turn signal lights Sonnyboy_imp 9 840 09-24-2017, 05:31 AM
Last Post: Retsel_imp
  Deactivating front running lights rsp123_imp 17 1,289 08-06-2016, 10:40 PM
  turn lights lol_imp 5 382 06-18-2016, 12:10 PM
Last Post: lol_imp
  Work Lift Question Ron in MO_imp 17 1,105 12-17-2015, 03:22 AM
Last Post: redbirds_imp
  Tail lights and leds Dammit33_imp 8 597 08-11-2015, 02:15 AM
Last Post: hxd148_imp
