Check engine lights up. Not blinking
Mine is RS 2017 with 27,500km. Just had the check engine light coming up without blinking on the way home from work yesterday.
Bike running without any issue but just the yellow check engine indicator on. I'm wondering if anyone experience this, please share. Thanks
Someone with a factory service manual may be able to tell you how to determine what fault caused it. Without knowing that, I wouldn't ride it except slowly to the dealer or a qualified mechanic.
An addendum: things may different on the 2017RS, but the Owner's Manual for the 2010 bike says the engine (or PGM-FI) malfunction indicator lamp,
Quote:Lights when there is any abnormality in the PGM-FI (Programmed Fuel Injection) system. Should also light for a few seconds and then go off when the ignition switch is turned ON and the engine stop switch is at ⟳ (RUN).
If it comes on at any other time, reduce speed and take the motorcycle to your Honda dealer as soon as possible.
(05-02-2018, 05:48 PM)itstuantran_imp Wrote: Mine is RS 2017 with 27,500km. Just had the check engine light coming up without blinking on the way home from work yesterday.
MIL on= DTC is set = retrieve it and fix it accordingly.
MIL on indicates MPI/emission (if RS has PCSV) malfunction, whether history or present.
Don't experiment..
Good luck
pb
Yes, peter, but how to retrieve and interpret the DTC?
(05-02-2018, 09:55 PM)Cormanus_imp Wrote: Yes, peter, but how to retrieve and interpret the DTC?
The best is scanner since there is no blinking which may indicate system normal at present. My advice = see dealer for best accuracy.
Do not delete without reading DTC.
There is a procedure in my 13-14 shop manual (not RS)..p 5-12 to 5-16 for automotive oriented users...
pb
Wait, how did you rack up so many kms on a 2017 already? Well done.
The CEL will illuminate steady at RPMs above 1700 or with sidestand up.
Smile, im man of move
(05-02-2018, 05:56 PM)Cormanus_imp Wrote: Someone with a factory service manual may be able to tell you how to determine what fault caused it. Without knowing that, I wouldn't ride it except slowly to the dealer or a qualified mechanic.
Thanks
Don't experiment..
Good luck
pb
Don't experiment..
Good luck
pb Thanks but this is beyond my own self service Smile
It's on steadily when turning the key on and either at idle RPMs at 1400 or above 1700. I kept on riding for 2 days and try to notice any abnormal signs but none so far but the CEL
Thanks
Don't experiment..
Good luck
pb
Don't experiment..
Good luck
Turn ignition switch on, with stop/run switch in run mode, without starting the engine.
If ECM has stored DTC, the CEL/MIL will illuminate 0.3 seconds, go off, then start blinking code.
If no stored DTC, CEL/MIL will illuminate and stay on until after engine is started, per the FSM.
Tuan, where in Vietnam are you located?
...something not clear...'17 RS with 27K, MIL on when not riding?????????????? or when riding....how was it at the beginning????
Huh
pb
Photo First Check Engine Light Ever on a Bike doug1976 2 229 01-14-2026, 06:47 PM
  Check your clips! Gone in 60 3 623 07-01-2025, 11:27 AM
  Basic Maintenance: Daily Check rdprdp01 17 1,404 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 677 08-22-2024, 09:39 AM
  Sound check what wrong tory_imp 3 424 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Valve check? Phat Ham_imp 26 1,937 01-13-2021, 12:36 PM
  Oil level difference between check zirconxi_imp 29 1,863 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  cam chain check max 0 189 04-22-2020, 08:26 AM
Last Post: max
   Turn lights would not work Ennsync_imp 15 1,093 01-02-2020, 02:02 PM
   Engine light Blinking tory_imp 25 1,800 12-04-2019, 10:38 PM
