Bead method of balancing tires, does it work?
Has anyone here used the bead method for balancing their tires? Specifically, the product "Counteract" seems to be the most popular brand. From google it seems like its superior to traditional weight balancing. Curious if anyone has used it and what their experience was, if it works you could balance probably 4-6 tires for 15 bucks.
Thanks
I dont personally understand how the beads would actually work and how their inertia based on their own mass would only want to stay in specific spots of a tire with equal centrifugal force but someone much smarter than me can probably explain how it works better to me.
I have been using a motorcycle tire balancing stand from harborfreight thats worked just fine the last few tire changes on a few bikes and had taken the high speed "shake" out of my front wheels by balancing them properly on more than 1 occasion.
If the beads do in fact work and work properly after I can understand them better than maybe I'd he willing to try them on the next change for comparison
I'm pretty positive this has come up in other threads in the past so I bet someone has used them to actually answer your question haha good luck either way!
I have the same question as MagnaRider. What is the science behind this balancing method?
Another product I was told about from another forum was the Ride-On Tire balancer/sealer. Basically, the same thing a dynamic balancer gel that will seal holes apparently.
  Cams, Compression, Head Work? boynton6spd_imp 12 948 08-08-2021, 02:27 AM
Last Post: old blue_imp
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,248 10-15-2020, 02:13 PM
Last Post: max
   Turn lights would not work Ennsync_imp 15 1,084 01-02-2020, 02:02 PM
  Tire Balancing tomas_imp 4 369 07-05-2016, 04:19 AM
Last Post: venturer434_imp
  Work Lift Question Ron in MO_imp 17 1,014 12-17-2015, 03:22 AM
Last Post: redbirds_imp
  When your oil filter wrenches won't work?!? Huladog_imp 12 894 07-27-2013, 02:21 AM
Last Post: MotoMichael_imp
