Tail lights and leds
I recently purchased an led strip for the stop run and turn signals, and it does not have separate ground wires for the turn signals, and as such they do not work. The run and stop lights work fine. Is there some way to make this work?
The led strip wires are:
1- ground
1- run light
1- stop light
1- l turn
1- r turn
Is it a known brand, or something form China via eBay? If you mention the brand and where you got it from, someone here may recognize it as something they already purchased and be able to help.
In my experience with them they usually just work off the one ground contact wire, you may have a bad unit or one specifically made for a certain brand only, like BMW.
Check the polarity of the stock wiring. Make sure the positive leads from the turn signals are the ones you're connecting. A check with a volt meter or light will help out.
Good luck!
It's a universal install led strip.
The polarity of the Turn signal leads on my 2014EX were switched. + as per the manual was neg. Try your meter on it, or just flip them and see what happens. You might blow a fuse...
Wires are as I assumed, green ground and colored positive. I've tried to wire it a few ways but all I seem to be doing is blowing fuses....
I found the turn signal wires polarity flipped on the 2014 versus the 2013 std. I wrote this up and yes the shop manuals are not correct.
(08-04-2015, 09:19 AM)Dammit33_imp Wrote: Wires are as I assumed, green ground and colored positive. I've tried to wire it a few ways but all I seem to be doing is blowing fuses....
On a couple of past motorcycles I assumed green was ground and I was wrong. You need to use a tester to see which wire is hot when you switch the circuit "ON".
On my 14 I found that the wires on the bike side of the harness were correct but the plugs themseleves were wired backwards from the factory. On my bike I kept blowing fuses until I used the Green wire for power and the other colors for the ground. This solved the problem.
  2017 tail light rattle Venteuri_imp 2 403 05-14-2024, 05:55 AM
Last Post: Venteuri_imp
  2017 Tail light housing swap dogclerk_imp 0 211 07-05-2022, 12:31 AM
Last Post: dogclerk_imp
  Wire Colors for Signals, Tail Light RedRoevr_imp 10 786 05-01-2022, 06:23 AM
  Tail light install problem iamheero_imp 9 755 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  LED tail light connector shahyaan_imp 10 957 11-28-2020, 09:33 PM
Last Post: shahyaan_imp
  2017 EX Tail light wire channel access TXBikerGuy 8 820 07-26-2020, 06:57 AM
Last Post: TXBikerGuy
  Tail Tidy and Plate Relocation jethrofelix_imp 21 1,785 06-05-2020, 12:03 PM
Last Post: run-tmc_imp
   Turn lights would not work Ennsync_imp 15 1,164 01-02-2020, 02:02 PM
  Samurai Tail Light wiring HWdesign_imp 8 718 08-04-2018, 01:25 AM
Last Post: HWdesign_imp
  Turn Signals/Hazard Lights - Not Blinking/Not Turning on mnm2008_imp 20 1,376 06-24-2018, 02:39 PM
