Work Lift Question
I plan to do some projects that won't allow me to lift the bike with the center stand. What are my options to lift the CB1100 securely and safely?
I have a Craftsman hydraulic motorcycle lift, but too many parts sit below the frame rails. I also have a sport bike swing arm lift.
I'm curious to see what fellow forum members are using or might suggest?
I have front and rear paddock stands if I want both wheels off the floor at the same time.
I also have a Baxley front wheel chock if I just want to raise the rear wheel. It all depends on what the job is.
I use a Harbor Freight motorcycle lift. Once you upgrade the front wheel chock (I haven't done it yet), it's great for do-it-yourself at home garage mechanics like me. There is a plate on the rear end of the platform the easily removes to simplify rear wheel changes. They list for $429 but are almost always on sale for $299. I found mine locally in like new condition on Craigslist for $200. If you need to raise the bike, you can securely strap the bike down and use a small floor jack under the bike.
http://www.harborfreight.com/1000-lb-cap...68892.html
I also have a table lift for working on my bikes. I can strap the bike down from the front or rear. If I wasn't able to make use the center stand then I'd probably purchase a motorcycle-specific scissor jack for further manipulation of the bike.
[Image: 8f0fee77c60544de90c1187cb165dfd8.jpg]
Nice looking Golden Retriever, Guth. He/she appears to be mesmerised by the beauty of the CB just like the rest of us. Shy
(12-13-2015, 02:42 PM)EGAlvarez_imp Wrote: I use a Harbor Freight motorcycle lift. Once you upgrade the front wheel chock (I haven't done it yet), it's great for do-it-yourself at home garage mechanics like me. There is a plate on the rear end of the platform the easily removes to simplify rear wheel changes. They list for $429 but are almost always on sale for $299. I found mine locally in like new condition on Craigslist for $200. If you need to raise the bike, you can securely strap the bike down and use a small floor jack under the bike.
It just passed, but you can usually find this lift for sale during Black Friday for $195 and the upgraded wheel chock for 20% off, as well. I bought mine for that price a couple of years ago. With the better wheel chock, you still need to strap the bike down, though.
For anyone that buys this lift, make sure you check the hydraulic ram's oil reservoir (and buy oil when you buy your lift). Mine was dry and the unit would have basically failed immediately if I had not checked. I learned about this from the comments on the unit from their website.
Thanks for the great ideas. Sounds like a Harbor Freight motorcycle lift may be in my future!
Buy ANYTHING from HF online and you will get email sales every day of the week... don't see many paper catalogs or sales these days so maybe they have gone paperless? I generally drive into San Antonio and buy supplies for my business at their store.
That's weird. I buy a bit from HF (was just there last week) and only get paper mailings (catalogs) nothing electronically.
Redbirds has a lift with a front wheel chock that looks to be much better. There is a pic somewhere on the Forum, maybe he will re-post it if hes watching this thread.
My wife calls HF " The Stinky Chinese Tool Place", so one day I Googled her name for HF and low and behold that's what came up.
  Cam Chain Tensioner/Lift ? bflint 6 875 07-18-2025, 10:56 AM
  Bead method of balancing tires, does it work? MagnaRider 3 434 01-06-2025, 03:03 AM
Last Post: MagnaRider
  I've already put my CB1100 up on the lift Guth_imp 21 1,594 12-09-2021, 01:18 AM
Last Post: Raceman_imp
  Cams, Compression, Head Work? boynton6spd_imp 12 991 08-08-2021, 02:27 AM
Last Post: old blue_imp
  What ‘Bike Lift’ do you recommend? ride4now_imp 17 1,104 01-11-2021, 02:05 AM
Last Post: j3gq_imp
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,489 10-15-2020, 02:13 PM
Last Post: max
   Turn lights would not work Ennsync_imp 15 1,116 01-02-2020, 02:02 PM
  CB1100 assymetrical cam timing, lift, and duration. Roger the shrubber_imp 23 1,330 02-18-2018, 10:29 PM
Last Post: jimgl3_imp
  Harbor Freight Motorcycle Lift Frulk_imp 10 775 03-15-2016, 04:30 AM
Last Post: AzBob_imp
  Anyone know of a front head lift stand compatible with the CB1100? chync_imp 5 468 10-23-2015, 08:31 AM
Last Post: kennyw
