No clutch shifting
I do both clutchless up and down shifts, not all the time though. Find clutchless upshifts, especially when driving 'progressively', better than the ham-fisted efforts I sometimes make and at lower speeds they can be very smooth indeed.
^^+1^^ l learned about clutchless shifts while working summers at a Honda shop in the early 70s... always thought it was a normal thing that everyone does.
I clutchless shift at least 2-3 times per ride.... not on purpose, though.
i do all the time grew up on dirtbikes so seems naturel to me
and this is why I don't buy used bikes.
(06-21-2021, 04:20 AM)The ferret_imp Wrote: and this is why I don't buy used bikes.
what do you find wrong with clutch less if done right its just as safe as using most honda trans are devolved in a racing atmosphere you think in moto gp they granny shift?
"if done right " is the key !
I think they put clutches on motorcycles that are meant to be used when shifting. I dont trust that everyone knows exactly what they are doing on every clutch less shift and transmissions are easily damaged, worn dogs, chipped teeth. I'd just prefer not to buy a bike that may have been treated that way.
I think in MotoGp they use transmissions called seamless gearboxes that are specifically designed for clutch less shifting at full throttle.
There are some ( but not all) street motorcycles which have factory quick shifters on which you can upshift but not down shift without a clutch, and some are designed to upshift and downshift without the clutch, but the CB 1100 is neither of those.
Moto gp in the 1980s use the same style trans as we have, a test drive tells you if their is a issue with the dawgs by the way in goes into gear if it feels unsure theirs probably a issue
I also have experience driving over the road trucks so thats just what i do
https://www.motorcycle.com/ask-mo-anythi...fting.html
An old Honda trained mechanic taught me the ways of clutchless shifting long long ago in a town not that far away. Very wise and strong with the force was he. RELTS were standard equipment back then... so maybe they are required.
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,319 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 1,002 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,084 11-22-2024, 07:49 AM
  Shifting issue Cormanus 31 2,391 05-15-2024, 12:59 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 250 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,584 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 659 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 519 02-21-2023, 10:48 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 399 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  brake & clutch adjusters The Gecko_imp 10 877 11-25-2022, 08:47 AM
