CLUTCH FLUID CHANGE
Anybody changed out there clutch fluid yet? i would think this fluid needs to be changed with the same frequency as the brake fluid if not more often. I believe the hydraulic clutch uses the same DOT4 brake fluid as the brakes. Is there access to a bleed valve to bleed the system. Those with service manuals, please chime in.
Nothing about changing more often than brake fluid….I imagine you'd maintain the same service interval when changing fluid. Same DOT 4 fluid as brakes and there is a bleeder valve on the clutch slave cylinder. They recommend use of brake bleeder to purge air but it can be done without...
My front brake and clutch fluids are getting darker but I " think" 2 years is the changing spec. My rear brake fluid is crystal clear.
There is a bleed valve for the clutch slave cylinder. Looks like its behind the big cover on the rh side, but the manual isn't real clear or specific. Doesnt mention removing any covers, but looking at my bike i don't see how you would get to it without removing a cover.
Edit: re- reading step 1: "support motorcycle using its centerstand securely. Remove the left crankcase side cover."
In order to do that, you need to remove the pinch bolt and then remove gear shift arm from the gear shift spindle. Then you remove 3 screws to remove the cover.
It is on the left side. you need to remove gearshift arm from the spindle and then remove the plastic side cover to get access to the clutch slave. The bleed valve should have a plastic protective cap on it.
Speed bleeders are awesome - makes the process quick & painless. I have them on my VFR and LOVE them.
You'll need 4 to swap them all, you're looking at like $15-20 - http://speedbleeder.com/
How does a speed bleeder work? Nevermind..went to their website and read about em. Interesting.
Thanks all for the posts. Maybe someone can take some pics of the left cover removed from the bike showing the slave or the schematic in the manual. If I am not mistaken, speed bleeders replace the standard bleed nipples on brake calipers/clutch slave and have a small spring loaded check ball in them. Hook a vacuum operated bleed tool to the speed bleed nipple and draw a vacuum. As vacuum builds, the check ball opens and allows fluid to be drawn out. Release vacuum and the check ball re-seats and keeps air from entering the system. Speed bleeders are a convenience item so you do not have to work a wrench to open an close the bleed nipple.
Naturally the CB 1100 is not listed on their fitment chart, but it looks like almost all Hondas take the same ones
Well there are still a few to choose from. Who knows which are the ones actually required? Post it up gents.
Speed bleeders are fine, but there is a simpler, cheaper, cleaner, and very effective alternative.
Get a length of clear tubing that fits over the slave cylinder leed nipple. Run the tubing to a small clear jar that has a couple inches of brake fluid at the bottom. Submerge the tube end in the fluid.
Open the bleed nipple and the master reservoir top. Pump the clutch lever. The old fluid will begin to flow out through the tube. Continue cycling the lever while topping off the master reservoir.
As soon as you see clean fluid coming out, you are done. Close the bleed nipple, remove the hose, and go for a ride. The lever will be firm because this method removes any air as well as changing the fluid.
  Replace clutch Lever Davidjill_imp 10 935 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,040 11-22-2024, 07:49 AM
  Brake fluid flush CB1100@2013: photos valkyrie_rider_imp 0 239 02-13-2024, 10:28 AM
Last Post: valkyrie_rider_imp
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 237 02-13-2024, 10:27 AM
  Clutch Fluid Wagonpeddler_imp 32 2,431 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 619 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 487 02-21-2023, 10:48 AM
  Synthetic Brake Fluid Wagonpeddler_imp 3 367 02-18-2023, 07:49 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 367 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  brake & clutch adjusters The Gecko_imp 10 772 11-25-2022, 08:47 AM
