brake & clutch adjusters
My adjuster wheels (for clutch or brake) are very, very hard to turn - in any position of the levers including released.
Adding oil or cleaners around and under the adjuster wheels hasn't helped the matter at all. Has anybody found a good way to get them working better ?
You push the lever forward and they are still difficult? One would think some WD-40 or silicone spray would make them turn easier. If not maybe PB Blaster?
Maybe take a set of slip jaw pilers and work them back and forth a little?
You may remember that my bike has a "dirty" history, I reported this a while ago.
And yes, I can confirm ...
- difficult in any position of the levers
- WD-40, a little or a lot, and patiently waiting for the results, does not solve the problem.
I can adjust them with a screw driver and a lot of force, but this ain't ideal.
Doesn’t look like it comes apart, but I haven’t checked my bike.
(11-19-2022, 11:48 PM)The Gecko_imp Wrote: You may remember that my bike has a "dirty" history, I reported this a while ago.
Well, the thing is once you get them where you want them, there is little need to move them again. Mine have been in the same position for 9 years now. Mine are probably "stuck" now too.
The levers should be removed at the pivot bolt and cleaned and lubed once in a while. It may have been damaged just a little and is pinching the adjustment wheel. You say you move it with a screw driver, as in, pushing it like a pry bar or turning a slot in the screw? Hope that makes sense. TM
Ferret is right, Nobody needs to adjust 3 times a week .... BUT I couldn't test for the best position while riding. That's where it would have been nice to be able to adjust without tools.
No I have it in the right position. Thanks for your help guys.
(11-20-2022, 06:08 PM)The Gecko_imp Wrote: Ferret is right, Nobody needs to adjust 3 times a week .... BUT I couldn't test for the best position while riding. That's where it would have been nice to be able to adjust without tools.
That makes a lot of sense Gecko
(11-21-2022, 05:52 AM)m in sc_imp Wrote: wd 40 is a cleaner, just fyi. thats good to get the grit and stuff out, by flushing it with the wd. then use oil that will stick. cable lube is good for this type of mechanism in my experience. .02
(+1) Agreed.
I missed that in the past, thought innocently that WD was both cleaner and oil. But when I think about that now, I think it's nonsense. So - thanks for your clarification.
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,305 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 1,000 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,084 11-22-2024, 07:49 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 249 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,559 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 659 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 517 02-21-2023, 10:48 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 399 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  Clutch Lever Full Engagement odelegacy_imp 41 2,701 10-28-2022, 09:27 PM
  Clutch replacement advice misterprofessionality 31 2,588 06-11-2022, 05:51 PM
